Hi i have 1998 R34 GTT 2 doors for Wrecking black colour.
Engine complete package $2800
Gear box conversion $2000
Led tail light $350
Boot Lid no spoiler,no hole $300
All 4 wheel with good rubber $750
Gear stick surrond $120
complete brake kit $1000
complete interior $600
RHS power window switch $200
LHS power window switch $100
that all i can think of atm if you need any parts and it not on the list please ask.
Edited by rlzrtg
https://www.sau.com.au/forums/topic/265562-wrecking-r34-gtt-5-speed-manual/
  • Replies 55
Led tail light $350
I am after the boot lining plastic just where the boot latch connects. Please let me know the price shipped to sydney.
Can you show me which part is double Din dont want to give you the wrong price.
just that pocket with the flap lid.
where are you located by the way. cause i also need the white petrol tank lid. white lid inside the boot gaining access to the tank itself.
prices for both as well thanks
ill try and find pics of the tank lid.
sorry mate that item been sold
im locate in wetherill park.
price on the gear stick surround and the small trim that goes above it and around where the radio would be.. the yellow line is actually right ontop of it
gear stick surround $80
the other piece is sold.
Air con climate control unit cover.
How much for just the cover off it? Dont need the actual unit or controls. Cheers
Oh and the S badge on bonnet :)
Edited by Granthem
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
