Hi i have 1998 R34 GTT 2 doors for Wrecking black colour.
Engine complete package $2800
Gear box conversion $2000
Led tail light $350
Boot Lid no spoiler,no hole $300
All 4 wheel with good rubber $750
Gear stick surrond $120
complete brake kit $1000
complete interior $600
RHS power window switch $200
LHS power window switch $100
that all i can think of atm if you need any parts and it not on the list please ask.
Edited by rlzrtg
https://www.sau.com.au/forums/topic/265562-wrecking-r34-gtt-5-speed-manual/
  • Replies 55
Led tail light $350
I am after the boot lining plastic just where the boot latch connects. Please let me know the price shipped to sydney.
Can you show me which part is double Din dont want to give you the wrong price.
just that pocket with the flap lid.
where are you located by the way. cause i also need the white petrol tank lid. white lid inside the boot gaining access to the tank itself.
prices for both as well thanks
ill try and find pics of the tank lid.
sorry mate that item been sold
im locate in wetherill park.
price on the gear stick surround and the small trim that goes above it and around where the radio would be.. the yellow line is actually right ontop of it
gear stick surround $80
the other piece is sold.
Air con climate control unit cover.
How much for just the cover off it? Dont need the actual unit or controls. Cheers
Oh and the S badge on bonnet :)
Edited by Granthem
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
