Hey All,
I am going to paint my plenum black but it will mean my car will be off the road again (which is no good for me).
I thought I might buy a GReddy Plenum, get that painted and then swap it over in one day (I have to replace my knock sensors as well once the plenum is removed).
The question is, is it a worthwhile upgrade? My mod list is quite high:
Built/Forged 26
Arias Pistons
Argo Conrods
R33 GTR Crank
Balanced Bottom End
1.6mm Head Gasket
Jun 272 10.5mm Lift Cams
Tomei Cam Gears
Jun Oil Pump
N1 Water Pump
Trust Sump Extension
ATI Balancer
GReddy Pulley Kit
6 Boost Manifolds
GT2860-5's
Trust Dump/Front Extensions
Apexi PFC D-Jetro
Sard FPR, Rail, 800cc Injectors
Splitfire Coilpacks
Bosch 044
So maybe it will give me that extra flow.
Anyone here bought them and was happy/disappointed?
If it is not a worthwhile upgrade then I will just buy another stock plenum and paint that.
https://www.sau.com.au/forums/topic/265591-rb26-greddy-plenum-vs-stock-plenum/
Mate if I was you I would save your money and paint the std one.They get big power levels with the std plenum still in place.
You can spend the money to improve something else on the car.Why not just send the old plenum down to the painters early
in the morning.While your waiting for that to get painted you can change the knock sensors and what ever else you need to
do to the car in the meantime.I cant see why you cant get it done all in 1 day just have to be carefull not to chip the new
paint still maybe a bit soft but the painters should stick it in the oven for you though.
depends on what power your aiming for i think the stock plenums do alright /on par up until around the very high end lets say 500 kw then when your trying to squeeze your motor for everything go for a greddy one
Yeah...I dont know about that. I wouldnt.
The collectors can warp over time, I know mine was bent like a banana when I checked it, I wouldnt risk the 2 odd hours each way for a day or so of your car being off the road...
Better to keep the entire intake side in sets.
some of the fastest timeattack/circuit cars run single tb's. 1 explanation i've been given from the owners is that the std plenum/tb's flow approx 30% less than say a hypertune plenum/90mm tb, throttle response is as good if not better.
not to mention the std plenum is known to run leaner at the back than the front
Lag or less throttle response? Switching from a stock 25 intake to a stock 26 intake with ITB's and lost noticable low end due grunt to the short runners on the 26 intake. I think my friends home made short runner intake for his 25 with a Q45 has pretty snappy throttle response, even compared to mine. I think throttle response is kind of one of one of those over rated internet buzz words. It sounds real snappy blipping the throttle out of gear, and I get almost feedback when I hit the gas in gear, but I'm not sure how much faster I am.
Yes but its how the car "feels" as much as anything else.
A car that feels doughy and sloppy is not a good end user experience ;)
A car that feels nice and snappy, responsive is much more rewarding and fun.
Whilst over a 1/4 mile it might run the same time (under full load etc), but its driving around town where you appreciate a nice snappy feel like that.
I cant see how you could possibly have better throttle repsonse with a single TB compared to six smaller ones basically bolted straight to the ports in the head?
As for lean on one cylinder, most a/m plenums have the same problem anyway with distribution.
Has anyone driven a SR20 Silvia then driven a GTI-R straight after? Tell me you cant notice the difference...not power wise but response.
And you cant really compare a built 26 with std TBs which probably runs lower CR too. My car is slightly 'doughy' compared to a factory 26.
A car that feels doughy and sloppy is not a good end user experience :D
I can completely agree with that. :P I just wanted to throw out there that it is the particular effect everybody if chasing with these mods and all this effort, not more hp or better low end power. A lot of people out there confuse the two I think.
^^ ye and they also are not street driven.
Race cars, dedicated track cars, always bad examples.
As for the lean, that's simply and easily fixed with some minor correction/trim when getting tuned.
not street driven but throttle response and low end power delivery is almost everything. same as why most cars run low mount twins instead of big singles.
so ud rather have a poorly designed manifold and tune out the flaw? I'd rather have a proper manifold that flows evenly as possibly.
Id still like to see back to back flow tests.
Stock response? Id like to see that honestly! So far the single tb cars ive driven have had a noticible lag time
how was the heads setup on the different cars? did the different cars have the same tune? or did some ahve shitty fueld up tunes and some nice and crisp?
only the crap plenums that only look pretty have the shitty in-balance of flow, the proper ones are near perfect 1-6.
Who?
no1, i was having a dig :blink:
Stock heads both cars
Both tunes were freshish, cars both well taken care of with quality parts used
i bet both were 2.6's though, silly kents shoulda went 3.0, problem solvered
bit ot but i hate how 26's are down low, throttle responce mite be 'snappy' but theyve got n o t h i n g until about 4
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
