After much deliberation I have decided to tentativly put this car up for sale.
Im not going into massive details interested people can get in contact with me for more info.
Chassis/suspension
Fully welded in rollcage. Protrudes the firewall, very extensive cage, Best quality race tech steel used. Approx 12K worth of cage.
Selected body gusseting through out.
Custom suspension pick up points using many custom and aftermarket/modified arms. Basicly everything from rollcenters to toe is adjustable front and rear.
Including lower control arms
upper control arms
caster rods
rack arms and end etc etc
The development thats gone into the suspension must be seen to be appreciated.
Any pannel that could be lightened has been.
FPR boot lid carbon bonnet etc
glass removed etc etc
Coilovers (will release info accordingly)
Selbys sway bars
New bushes/rose joints through out
Eibach springs (several sets to go with it)
Custom made front under body diffusers and bumper
Cobra sebring FIA approved seat
RPM suede steering wheel.
6 point FIA approved harness
Completely re-wired car. bare essentials
Brakes
Porsche/brembo 997 cup car front and rear callipers. 6 front 4 rears
380mm fully floating front rotors
355mm fixed rear rotors
Pagid pads front and rear
One off machined calliper adaptors to suit
Braided earls lines
Tilton over hung Steel pedal box (6.25 ratio)
Tilton clutch and brake master cylinders
Engine
Engines in the car are handled by Sam at westend performance. Anyone thats knows him will attest that his pretty anal with race engines and since using him failures have been few and far between.
I have a few engine options but the basic run down is.
Preped 05U block.
Balanced apexi crank shaft
ATTAKD I beam rods
CP 87mm pistons and rings
Extensive head development including revised Apexi Vmax cams (in reigion of 272 11.8)
Apexi Vmax springs and retainers
stainless valves and new guides
Ported obviously
Custom made buckets and shims to suit smaller base circle cams
5 stage DRY sump system
Barnes 5 stage pump
Peterson boot mounted tank with inline earls filters
Custom made GTR sump with 3 scavengers from sump one from the rear of head
Custom made scavenger manifold
Ross tuff bond balancer with madrel
All braided Earls lines and filters used everywhere. Breather tanks etc all have earls lines as well.
currently has garrett -10 turbos fitted with modified external 38mm twin wastegates
Straight through dual side pipes.
Fuel system has an RCI boot mounted cell with dual 044's, 3/8ths lines 1000cc rochesters and a sard reg.
Ecu is a Haltech E11V2 tuned by JEM has made well in excess of 400Kw
AIM MXL pro data logger (may or may not go with the car though)
Transmission is a kinder suprise at the moment but im certain it is an after market gear set of some type but I have a busted hollinger that may go with it.
Clutch is an OS giken twin plate approx 80% remaining was out last week.
Modified front diff center (stock ratio)
Nismo 2 way rear diff (stock ratio)
There is loads and loads more about this car that I dont want to openly disclose but really anyone interested can get in contact and im happy to run through the entire cars history.
It was at wakefield park Tuesday just gone. It recorded a 1:04:88 fastest and a slowest flying lap of 1:05:96
I have all the data from this day should buyers want to see it for themselves.
Will have some times and data from oran park tommorrow as well..
As for price again im not really open to disclosing but happy to disscus a sum with interested buyers.
https://www.sau.com.au/forums/topic/265600-r32-gtr-3d-sports-sedan/
  • 3 months later...
