Hey all,
I know this has been asked a lot but about a day or so ago i noticed that my oil pressure guage is showing 8 and over (going past the last mark on the guage) should i be worried. I thought i may have had something to do with my white face dials getting installed and them buggering up the needle but they didn't cause it was fine after getting the dials installed.
I have not checked my oil yet, i will do that, i have only had the car for a month.
Cheers
Kris
https://www.sau.com.au/forums/topic/26561-oil-pressure-very-high/
Kris,
Really high oil pressure is usually due tot he wrong grade of oil being used.
What is the pressure at idle when warm? And what it is at cruising speeds when warm?
If in dought, dump the oil and filter and change it to something the guys on here recommend.
Cheers
Jayson
I would suggest it's the sender. Disconnect the wire from the sender and see what happens to the gauge. Then try earthing the wire.
(had a similar problem in my R30 - oil pressure without the engine running, just with key in 'ON' position)
sounds like the factory gauge/sensor playing up as you mentioned it only just started happening, i.e it was fine with the same oil....
but check oil to see level, and for contamination (water or fuel etc.) and buy an aftermarket gauge for more accurate indication.
  • 1 year later...
My Oil pressure reaches high's only in the mornings when car is cold. I hesitate to drive because the needle just keeps rising unless i put the car in neutral wait for it to drop then try driving again, is this normal
after engineis warm it sits in the middle.
Normal , the oil is too thick when cold .
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
