just doing some homework. would anyone here know how these 2 gearboxes are different? if they are at all?
There are a number of major differences, although the gears themselves are very similar:
- bellhousing is different in terms of bolt pattern. Also the starter motor bolts to the side of the bellhousing and the starter body faces toward the rear of the car.
- Z32 uses a 'remote shift' arrangement where the gear lever (shifter) isn't attached directly to the gearbox. There's a rod arrangement connecting the gear lever to the gearbox.
- extension housing is different because the gear lever doesn't mount to it, plus it's a bit shorter.
shit. thought it would only need an RB bellhousing to make it work :S
OK, you've waited long enough.....sorry :stupid:
There IS a gearbox that was used with VG series engines that is very similar to the RB25DET gearbox, with the only real difference being the bell-housing. A mate has one behind a VG30DET in a 260Z. I believe the gearbox was used behind VG33, which was the engine in local spec Navara (I think around mid 90's ??)
Anyway that's what I think your after, but don't expect it to be cheap.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
