my mate has smashed his 32 GTR few weeks ago, passenger side banana'd
FRONT LIP AND REAR INTERIOR TRIMS ARE NOT!! AVAILABLE!
front bar only, no lip. $150 (needs a 10cm section to be plastic welded, has n1 slots)
front guards $600/pair
front reo - $150
rear reo - $150
bonnet $600
front lights $300
front grille $200
front brakes (incl. DBA slotted rotors)/rear brakes incl all 4 hubs $800
rear cut with quarter panels $1000
seats front / rear $700
drivers door with glass $250
centre console $50
stereo/shiter surround $75
door trims $100/pair
carpet $50
cluster surround with switches $100
RB26DETT with fresh recod head ($2500), just last week!! loom and ecu $4500
gearbox $500
bootlid and wing $300
complete body loom not incl dash, but all the way to rear incl fuel tank etc etc $400
mines ECU $250
IF THERE IS ANYTHING U NEED PLEASE PM ME AND ILL SEE IF WE HAVE IT AND ITS INTACT!!!
pm me with ur email address and ill send pictures!! i have pics of most of the stuff.
https://www.sau.com.au/forums/topic/265635-r32-gtr-most-parts-available/
What colour is the bar?
Would you split the seats? need fronts, already have rears.
Can pick up this week.
Paul
0403433579
no aftermarket parts sorry, possibly a cat back exhaust, gota check the condition tho if its bent/damaged, honestly cant remember
did you find out about exhaust?
im after a centre part only depending on the style of exhaust it is
can you post pics
cheers
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
