The year of the car is not sufficient to tell what type globe it will require.
R32's have a wide variety of headlight configurations. My friend and I both had 32 gts-t's, same year of manufacture, both with projector style globes yet both had different globe requirements.
If you take the globe out and go to autobarn or somewhere like that, they will be able to tell you the glode type.
Also, HID's in many cases for r32's are not a straight fit... generally from what I have seen you need to modifiy the HID globe to enable it to be held in place.. hence why i did not get install the set i bought.. I probably should sell them now that i think about it.
Hope this helps.
Hope this helps.
Driftking 06... what he means by that is.... There are 2 types of R32 Globes.......... one uses the H1 in the projector style and the other Uses H3c....
the most common one is the H3c....... dont use the H3..... its slightly different you gotta solder shit etc to fit....... i wouldnt bother
any HID kit that can suit either H1 or H3c (depending on which one you got) will fit your car but will need to wire it up and mount the Ballast at a suitable spot.
Edited by eeiko321
