Gt-r Sets 'lap Record' At The Nurburgring
Never use thread tape on such things. Teflon thread compound, in a tube. Loctite, and all the usual other suspect brands have thread sealant.
I think throttle cables are one of those things that you can stick together out of parts if you need to. Just buy one and try it. If it doesn't work, sell it on.
I have a 32 GTR and recently had the standard 5 speed rebuilt with R33 s2 syncros and have this exact same problem! Gearbox shifts fine when not under load but doesn’t matter what gear I am in and if I try and change gears under power then it always misses the next gear and the pedal goes to the floor… I have a cube short shifter on it as well and have the recommended redline MT90 and Nulon smooth shift so not sure what’s going on..?
Does anyone use thread tape on the threads of this bolt or just bolt it back in?
