Hello,
I am going to be getting the oil/water lines created for a standard turbo setup on a skyline GTR.
The shop im getting them made from are wondering what side of braided hose they should use and the AN Fitting on each side.
And to replace the banjo bolts, whats the NPT size on the turbo (both oil and water) and on the block (both oil and water)
Also, what is the size for the coolant return lines?
I have tried searching, have not found a definite answer.
Thanks guys,
MUNDA
https://www.sau.com.au/forums/topic/265730-braided-oil-water-lines/
-6 coolant and -4 oil
banjo's i would assume are metric, i'm guessing but they'd be around 12mm for oil and 16mm for water. just take a std banjo bolt down to ur local bolt shop and ask them the thread size/pitch
