does anyone know anything about setting up injector lag, beyond just inputing the numbers from the manufacturer?
i've been mapping the car but having problems getting a good idle and mpg and the problem seems to be injector lag. i get the car setup ok, it drives ok, afr at idle 14.7 within a few points with no o2 sensor feedback. if i increase the lag a half point eg 0.18ms to 0.24ms my afr's go rich, remap the car and the car drives and idles better. i'm up to +0.28ms so far with the manufacturer saying it should be +0.19ms and the car is a lot better.
does anyone know what the professionals do to setup injector lag?
i'm thinking what's happening is the injector is being opened too late by the ecu because the setting is too low, thus spraying the back of the valve as it closes. this pool at the back of the valve doesn't burn on this ignition nor on the next, it's just wasted fuel (bad economy). the wideband doesn't pick this up because it cant sense unburnt fuel, spray the sensor with petrol and it doesn't read rich. so, the lag is made greater and the injector fires earlier, this time it gets more atomised fuel ito the chamber for the combustion and my afr's go up, readjust the injector duty and the whole thing is timed a lot better so the car runs better.
does this sound ok?
i'm wondering if this should be repeated until the lag adjustment causes it to go leaner rather than richer. seems logical to me.
any input would be greatfully accepted, unless it's lies
https://www.sau.com.au/forums/topic/265774-injector-lag/
sorry for thre lack on info...
RB25DET - nismo 555cc injectors - power fc
current setting are 50% correction and +0.40ms latency!!! has never idled so well and runs around 15 AFR on light load and drops nicely as it moves lower on the map...
oh and on idle its slightly rich..around 14.2
https://www.sau.com.au/forums/topic/265774-injector-lag/#findComment-4538377
i know what it should be..thats not hard to find...
i am thinking that maybe the nismo 555s are not 555cc?!?!?!? i have found reports of this is a few places around the world... dont really feel like pulling them all out to get tested but i might have too...
i think this is the begining of finding something with my car that has never been quite right...
https://www.sau.com.au/forums/topic/265774-injector-lag/#findComment-4538513
have you tried it with those settings? if you bought nismo 555s theres no way they'd be flowing over 700cc (which would need the 50% correction)
the fact that you've had to add so much latency correction over the recommended settings means your size correction is too low. more positive latency correction adds more fuel, which makes up for your size correction being 16% too low
https://www.sau.com.au/forums/topic/265774-injector-lag/#findComment-4538539
how does more injector latency change the amount of fuel they flow??? i thought latency changes the time the injectors fire in relation to the CAS signal and also spark timing???
if the injectors fire too late then there could be fuel atomising on the back of the valves as they close and waste fuel.
with the normal settings for the nismo 555s i can always smell fuel a little around the car..particularly on idle.
however with the new settings i smell less fuel...
https://www.sau.com.au/forums/topic/265774-injector-lag/#findComment-4538550
latency is the time it takes for the injector to open and start squirting fuel. the higher the latency the more time the injector has to be pulsed with no fuel flowing (while its opening and closing). so therefore if your telling the ecu it takes ages to open and close it'll pulse for longer to inject the same amount of fuel
https://www.sau.com.au/forums/topic/265774-injector-lag/#findComment-4538564
every time i have tuned a car the injector settings have been no where near where the internet people tell me it should be.
The sooner you start using your own head and start working it out yourself instead of worrying what people say on here the quicker you will get the problem solved and you will learn how to tune cars alot faster.
I like to keep the injectors as close to 100% as possible. I don't care what injector it is. after you do 10 or 20 of them you start to see a trend in what works and what does'nt
https://www.sau.com.au/forums/topic/265774-injector-lag/#findComment-4539210
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
