I found this on ebay, Link
IMO, you can add an RB26, and even an Autech kit (which this one doesn't have) but that still doesn't make it an Autech Stagea. its along the same lines as putting an RB26 and a GTR kit on a GTST and passing it off as a GTR, its wrong.
also, i didn't think you could comply a car that has had an engine conversion :D
oh that looks neat. very sleeperish ....
but yeah, chasis modifications for inlet pipe would be a pain to pass over here with the AIR BAGS cumple zone :S
and might of listed it as AUTECH, with that cheap price it catches peoples attention ... got yours right ? now your advertising for him. i think his sneaky plan worked
not exactly what i was getting at but you have a point. lol
I am pretty sure Autech stagea starts off as a standard RS4 Rb25det and gets replaced by a rb26 in the autech factory.
Need someone to check their genuine autech and have a look at the engine plate tag. I think it is still listed as a RB25det
I have only ever looked at one genuine autech engine bay and it had a hole hacked thru the chassis for the intercooler pipe.
Did not look very "factory"
I might be wrong.
AFAIK, they start off as a standard shell, but have structural changes made before assembly. I seem to recall seeing something on an Autech brochure showing extra reinforcing around the C pillar, not to mention bolt-on braces under the floor. The marketing hype has had the desired effect here, that's for sure.
My Autech had no extra bracing around the "C" pillar, i was under the impression there was something there to but nothing. All the bracing under the floor bolts striaght up to a standard RS4.
The holes for the intercooler piping on mine had been done with a hole saw and a drill, nothing to rough about it. We just did the same with the swap. There was alot of mods to the panel under the rad support that i could see, little trimming and enlarging of holes, also the ends of the chassis rail are trimmed back for the blow off valve return pipe.
None of it looked "aftermarket" was all done like factory.
And yes all autech's are plated as a RB25.
Edited by msports180
So when you run your Autech Vin number thru Fast, does it call up a Rb26 or Rb25?
Also it makes me laugh everyone is concerned about cutting a hole thru the inner guard for aftermarket FMIC when a ADR approved and complianced autech is done the same way, ie an after thought. Where as a factory built and design GTR has a reinforced extra peice of metal around the hole.
When you fast the autech vin its comes up with a little thing saying its an autech listed vehicle (this allways confuses the nissan parts person) and yeah lists RB26.
The autech's are the same as GTR's to where it goes thru the guard in the way that the piping dosnt just pass thru, there is a part that actually bolts in place, a hard pipe, so this will add some strength to that area.
I might be wrong.
check out the engine plate on this autech for sale. . . . i was reading OPTION mag once and said that some have KAI written on the plate some where , but forgot there reason for during so, somthing to do with modifications ....
Geez, I'd even be nervous with a legitimate one if I was pulled up by the boys in blue and they challenged the build plate-vs-fitment...
I've always wondered 'how' some of the modified cars get through - you know, high mount T88's etc...
what makes you say that Hugh?
Well it appears to have black face dials and I am under the impression S2 have white face. Correct???
Also there does not appear to be a pic of the rear end. And I wonder why??????
Looks sus, sounds sus and FEELS sus.
Also, I cant see too clearly but does it have RB26 on the timing belt cover????
Edited by 66yostagea
this is correct... my autechs plate had it listed as an RB25DET.
Autech is not nissan - they purchase the vehicles before making the modifications, including paint. This is why the only way you could get a Series one in manual, or in black, was to buy an autech.
Technically all autechs are Nissan Stageas with a lot of 'genuine aftermarket' parts. Intercooler piping hole on mine was definitely a factory cut job.
Series 2 autechs have white faced dials, series ones have black, and even have the window in the centre for the automatic gear indicator.
He's not trying to pass it off as an autech... 'this one has been fitted with the RB26DETT AS PER THE AUTECH...'
He's just got autech in the topic title to get hits from people who are looking for autechs.
Obviously the car is not one...
to me it look like it has white faced dials, also the seats are series 2 seats. i know you could change them but why bother. i don't doubt its a series two. i think whoever picks it up is getting a good deal, cheap RB26 manual converted stagea. the only thing that would bother me is as some have said, and thats what trouble you may get into with the transport department, will it need to be mod plated anyway?
My S2 doesn't have white dials, but its a 25t X four, not an RS four
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
