Hi guys, I've been looking forward to one of these days. Never been before, never been to an SAU event before. Paid today and will fax off entry first thing in the morning. Going to book accomodation for me and the mrs. so we can come out and meet a few of you guys (and get on the sauce). :)
Cheers
Brendan Pryor
btw I have an R33 GTST
  • Replies 181
Paid and Faxed :(
Haven't been to one of these since I owned the gtst so with my current stocky setup I'm going from oversteer to massive understeer....AWESOME :(
haha. understeer sucks. will be good to see ya there. Shotgun passenger ride.
ALL GROUP PREFERENCES NEED TO BE LISTED IN HERE. LIST YOUR NAME ALSO.
its not guaranteed but we will try to group friends together.
Can you please put Tim Bryan and Russell Cunnigham in the same group.
Thanks.
[email protected] about the PM then....
Actually it doesnt matter. Scotsman or Shmicko.... I will cheat my way to the top :D
MADE it by the skin of my Teeth!
You and me both :D
Russ....more than happy to take you for a spin mate....besides I'm better on the skidpan with a nav ;)
As for group pref...I'd be happy being in a group with either Al/Shmicko or Scotsman :P
first ever Deca I'm praying for rain! lol
Ant the handbrake is an instant understeer killer... I need practice launching my thing... its either massive revs and smoking all 4 or it just bogs... should be interesting
I need to hit Scotsman up on how to drive these things quick around the cones
noted. as for groups with schmicko or grassscotsman, they will be in different groups so...
Not that fussed mate but I'll go with grassman :D
Nick....all well and good but the stocky handbrake shoes will only be good for a couple of turns before they glaze ;)
Have i missed something?
Who is schmicko?
Can i be placed mid group....................................please! ;)
Even though i have been to every DECA, i have driven in less than half, so i still like to look at others, to memorize which direction i need to go :D
Dammit...can't believe i missed this thread...been waiting for it for so long and even changed my flight dates to make it and i missed the boat...can i get on the waiting list? I'll fax my form across tomorrow...PM has been sent by Angel13th on my behalf too....
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
