  • Replies 181
wow that did fill up fast.
this time can David Talbot and Vince Ritchie be in the same group.
thank you in advance, as last time we entered at the same time but didn't know we had to put our names anywhere.
Entries:
Ryan Bell Sileighty
Michael Eichorn Sileighty
Tim Williamson R32GTST
Alan Calleja R33GTST
Ben Neale Cefiro
Martin Sullivan S14 200sx
Antony Ivancic R33GTST
Juliette Remfrey Pulsar/GTT
Darren Golding STI
Peter Canfield WRX
Russell Cunningham R32GTST
Brenton Homer WRX
Mark Homer WRX
David Talbot Silvia
Vince Ritchie R32GTST
Ash Crawford STI
Shane Janssen R33GTR
Nick Edlin R33GTR
Che Boocock R33GTST
Leon Stapley 180sx
Wayne Beaumont 180sx
Chris Stacey R33GTR
Shane Ellis Lancer
Marcus Stacey MX5
Justin Downie Forester
Leeanne Boyson WRX
Chris Thomson R33GTR
Ben Robinson R34GTR
John Richardson R33GTST
Behram Batra R34 4DR
Leigh Germain R33GTS
David Sidebottom DAT1200
Rob Sidebottom Pulsar
Phillip Mak Silvia
Roman Plotnikov 180sx
Luke Shulze R33GTST
Christian Brunelli STI
Jamie Lovett STI
Brad Humphreys Silvia
Mat Cross Corona
Nic Danger R32GTST
Dean Taylor 200sx
Jeremy Taylor 200sx
Mario West Evo7
Greg Calmer Silvia
Tim Bryan 180sx
Brendan Pryor R33GTST
Ross Brown Evo6
Anthony Snelling R33GTR
Tom Giordano R32GTST
50 NOT GROUPED YET
Reserves
Alex Norindr WRX
Clive Small Evo9
Matt Phillips R33GTST
Michael Napl STI
Gerald Tan Supra
Terence Ho R33GTST
Tim Lier WRX
Colleen Robins WRX
Christopher Starr M3
David Stubbs STi
that is 10 reserves. no more for now.
question with fire extinguisher. can it be mounted in my boot or does it have to be in my cabin??
these generally have to be mounted within reach whilst you are still in your seat.
most ppl seem to mount them to the bolt that holds the base of the rear seat on.
Entry List updated. two names below are now in.
Alex Norindr WRX
Clive Small Evo9
Clive says, excellent news tho' I have an evo 6 rather than a 9.
Mind, I'm happy to drive someones 9 if it's on offer :happy:
:) hey just a sugestion, can the reseve's come to deca incase other people pull out, and then Fill in for vulunteer's when we don't have enough.
also i'm bring somekind of support crew, i mean my mate (our mates, vince's mates) and i will talk to them this weekend about helping out, but so far none of them have said squat.
i'll inform them of the gift voucher's as incentive's and should hopefully get a reposnse shortly.
don't blame me for the dancin rabbit, i didn't do it. IT WAS VINCE !
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
