  • Replies 181
wow that did fill up fast.
this time can David Talbot and Vince Ritchie be in the same group.
thank you in advance, as last time we entered at the same time but didn't know we had to put our names anywhere.
Entries:
Ryan Bell Sileighty
Michael Eichorn Sileighty
Tim Williamson R32GTST
Alan Calleja R33GTST
Ben Neale Cefiro
Martin Sullivan S14 200sx
Antony Ivancic R33GTST
Juliette Remfrey Pulsar/GTT
Darren Golding STI
Peter Canfield WRX
Russell Cunningham R32GTST
Brenton Homer WRX
Mark Homer WRX
David Talbot Silvia
Vince Ritchie R32GTST
Ash Crawford STI
Shane Janssen R33GTR
Nick Edlin R33GTR
Che Boocock R33GTST
Leon Stapley 180sx
Wayne Beaumont 180sx
Chris Stacey R33GTR
Shane Ellis Lancer
Marcus Stacey MX5
Justin Downie Forester
Leeanne Boyson WRX
Chris Thomson R33GTR
Ben Robinson R34GTR
John Richardson R33GTST
Behram Batra R34 4DR
Leigh Germain R33GTS
David Sidebottom DAT1200
Rob Sidebottom Pulsar
Phillip Mak Silvia
Roman Plotnikov 180sx
Luke Shulze R33GTST
Christian Brunelli STI
Jamie Lovett STI
Brad Humphreys Silvia
Mat Cross Corona
Nic Danger R32GTST
Dean Taylor 200sx
Jeremy Taylor 200sx
Mario West Evo7
Greg Calmer Silvia
Tim Bryan 180sx
Brendan Pryor R33GTST
Ross Brown Evo6
Anthony Snelling R33GTR
Tom Giordano R32GTST
50 NOT GROUPED YET
Reserves
Alex Norindr WRX
Clive Small Evo9
Matt Phillips R33GTST
Michael Napl STI
Gerald Tan Supra
Terence Ho R33GTST
Tim Lier WRX
Colleen Robins WRX
Christopher Starr M3
David Stubbs STi
that is 10 reserves. no more for now.
question with fire extinguisher. can it be mounted in my boot or does it have to be in my cabin??
these generally have to be mounted within reach whilst you are still in your seat.
most ppl seem to mount them to the bolt that holds the base of the rear seat on.
Entry List updated. two names below are now in.
Alex Norindr WRX
Clive Small Evo9
Clive says, excellent news tho' I have an evo 6 rather than a 9.
Mind, I'm happy to drive someones 9 if it's on offer :happy:
:) hey just a sugestion, can the reseve's come to deca incase other people pull out, and then Fill in for vulunteer's when we don't have enough.
also i'm bring somekind of support crew, i mean my mate (our mates, vince's mates) and i will talk to them this weekend about helping out, but so far none of them have said squat.
i'll inform them of the gift voucher's as incentive's and should hopefully get a reposnse shortly.
don't blame me for the dancin rabbit, i didn't do it. IT WAS VINCE !
Guest
    • Hi Apex and welcome!
    • Probably too late to reply to this, but worth a try. It's not calliper flex, the calliper as a whole is moving so it has to be calliper mounting bracket flex.  Calliper mounting brackets are designed to stop the calliper rotating, they don't need to be designed heavy duty to stop the calliper moving in and out.  Whatever it is is not the major cause of poor pedal feel, the outer pistons are moving towards the disc rotor the same amount as the inner pistons are moving away from the disc rotor.  Hence no change in fluid usage, what extra fluid is needed to move the outer pistons is recovered from the inner pistons. For a calliper to move as a whole by far the most common reason is the rotor is not perfectly centred in the calliper.  The first thing I check is that hub face is perfectly clean, bare metal, where the rotor hats contacts it.  Then I check the that rotor is firmly held in place by at least 3 wheel nuts (or equivalent). If all of the above are confirmed to be in perfect alignment then I would check the piston sizes and ensure that the 3 inner pistons and 3 outer pistons have matching diameters (eg; 28/32/36mm).  I have seen a no name 4 spot calliper that had 1 of the 4 pistons a different diameter. Maybe I missed it, are both the callipers exhibiting the same problem? I would remove the transfer pipe and inspect it to make sure that there are no restrictions. Maybe you already have but if not I would return them with the video and have them confirm all of the above.   Hope that helps Cheers Gary
    • If you have the original log book and it didn't have a chassis number quoted, then no money required.  I have "rechassied" a number of race cars, no problem as long as you have the original log book.   Cheers Gary
    • Well the good news is that it won't run any worse with an atmo bov than it does with no bov, I've owned a few Nissans over the years (r32, s15 and now r33), the stalling issue caused by a bov or no bov while still having an afm is easy enough to live with, most people get used to driving them and just feathering the throttle when you come to a stop to avoid it stalling. Changing to a proper ecu with a map sensor is ideal but in the short term I'd just slap in the bov if you really want the whoosh sound. I looked into the pass through type maf like the R35 one above but decided against it as the amount of oil and crap flowing through the hot side would mean you'd have to clean it often to keep it working.
