1st question.....ok so my car drives normally then all of a sudden the car automatically revs the shit out of the car and hits 8rpm and doesn't stop so i pull over and turn the engine off and start again sometimes it starts normally other times revs to 5-6 by itself? wtf i blew my turbo last week and had plastic shit/little black pieces in the afm so cleaned it all out with air compressor and looked fine could my afm shit it self? this only happened after i blew the turbo. (and the afm was located on the intercooler piping now have changed it back to stock with a pod)...help please
running fuel pump, fmic, pod, r32 turbo with hks actuator at 12 psi, full 3inch exhaust
2nd question......i had a remap computer mods were fuel pump, fmic, boost tee 13, pod, r33 turbo, full 3inch exhaust,
now since i blew my r33 turbo and i put my r32 turbo back on can i still run the remap computer?
i know its better to get a tune but dr drift was booked out and other places.
and winton is this Sunday so need answers asap
3rd Question......i have a z32 afm can i unstall it with the remap computer and not have any problems (as in no need for a tune?)
cheers guys
cheers guys
As the throttle is cable driven, one might assume it relates to that somehow, as with the throttle closed the engine wouldnt be able to rev to 8k. I'd check to see if the butterfly is sticking open or that the linkages are not tight.
You can run the remap computer, but it might not run right, and might not be good for the engine. Best get it retuned.
I doubt you can remove the z32 afm without a retune, it might run as per question 2, but it might be bad for the engine or not work at all
you can run the car with the stock turbo and the remap suited for the r33 turbo but it will run rich. apart from that it will be fine.
you can not remove the z32 and put the stock one back on. it would start but be un drivable ;)
Did I do the remap for you?
cheers!
ok ill check those and with the z32 i have not instilled it on my car yet i want to put the z32 in now so will the car run fine with a remap and z32 not tuned???
