R35 Trans Temps
LSX-438
 Share
I've got my exhaust heat wrapped from the mid-joint back to rear mufflers. Hopefully that stops radiated heat getting to the tranny. The main reason, though, is to reduce in-cabin temps. However, I've noticed that my tranny oil temps sit around 86deg C on a spirited country drive, utilizing 4,5 and 6th gears. A friend's R35 on the same trip recorded Tranny temps around 90 Deg C ( with no exhaust wrap). Of course, this comparison is highly unscientific, but is interesting.
Outside temp was 14 degrees.
What are you guys recording?
Anyone tried the Willall tran fluid and recorded a significantly lower temp?
Absolutely incorrect. Newton described the three laws from which todays classical mechanics are based. The law of conservation of energy is generally accredited to Noether some 250 years later in the early 20th century.
 Share
    • This one isn't "on the street" per se, but it was on the street just prior to the photos being taken..... Mitsuoka Nouera, based on a CL7 Honda Accord. It was in the carpark of the Hanshin Nishinomiya train station "Ebista" shopping mall. I'd say they are very rare compared to other Mitsuoka models.
    • Do the shapes of the rice crisps really conform to the individual car model shapes or is it a bit of a stretch? I mean, do you know you're eating a BNR32 GT-R after having grabbed one from the can? 😁
    • Yeah, pure laziness My main reason for the change is the local crappy roads, car felt great going up the Mac Pass, and then back down the long way home via Jamberoo Mountain Road after ramming a sausage roll and coffee down the gullet  But as stated, good reason to head back down for a pie or sausage roll and coffee  Some nice cars turned up at the pie shop, my fave was a mint V8 Soarer coupe, the condition of it was truly awesome  Edit: plus to adjust the dampening I need to remove the OEM front strut brace, because it covers them, and remove some of the rear boot trim, I did have my little tool kit with everything required to do it with me, but, yeah, laziness
    • Any reason you didn't, like... change it while at the Pie shop so you could compare them on the way back? (all the more reason to go for another drive I suppose)
    • After a lovely little cruise up Mac Pass into Robertson pie shop on the weekend, and all the daily driving on our crappy roads, I decided to soften up the dampers a bit I've gone from 13 clicks from full soft to 9 clicks on the front, and from 8 clicks full soft to 4 clicks on the rear Whilst the car did handle great before, on smooth roads, it was a little bit harsh on pot holes and joins in the road, but only in the rear Also, my uneducated assumption is you need more dampening in the front compared to the rear, hence the front is set a little harder by 5  Will this help the budget spec BC RS coilovers on bumpy roads, I'm hopeful.....
