Ok, so I got my R33 RB25DET back from the tuner with a new turbo installation with the following:
Mods:
Garrett 3037 turbo
Top mount manifold
SARD 550cc Injectors
Bosch 023 Fuel Pump
Plazmaman intake plenum
FMIC
Profec B Spec II BC
PFC
and more supporting mods...
Although they done a good job with the turbo/piping installation, the tune im not too happy with and need some advice on.
Problems: When my car is cold, the revs surge from around 1300 to 1800rpm (this goes away when the car warms up), the tuner said he had no idea why this is happening and mentioned that the PFC doesnt have a cold start tuning option (if this makes any sense)?
The other thing he said was at high revs it knocked too much, so he reduced the timing right down to around 15deg IGN timing and now its very sluggish. He said that getting a high flow cat might fix this problem?
Anyone had any similar problems?
Cheers.
PS. I just checked the Injector latencies on PaulR33s PFC docs, and im not sure if the tuner set mine correctly, they read 70% and -1.30ms, souldnt they be 67% and +0.052 for SARD 550cc in RB25DET?
Edited by EVL-R33
https://www.sau.com.au/forums/topic/265840-help-r33-tune-problems/
Sounds like a shit tuner to me for one thing
The fact they state a PFC doesnt have a tuneable cold start is pathetic - you can do it via datalogit.
Either way, it wont be related to cold start on the actual ECU.
It'll be a leaky VAC hose somewhere, or a stuffed O2 sensor. Likely the first option
What exhaust do you have now? If you have a 3037 and do not have a serious flowing CAT - then it begs the question of what other mods are lacking as well.
Double edge sword here i think.
1. Average tuner
2. Average parts/setup by the owner
Both equating to an average setup.
He probably didnt do the stable idle procedure either.
You can put in temp correction through the hand controller from memory, so no excuses for that.
It was knocking so he reduced IGN to 15. Overall at the cas or in the map? Sounds like he just moved the cas, as removing timing from up top shouldnt make it sluggish.
What cat do you have?
Hey guys thanks for the replies.
I have a stock cat, and he actually though that might be one of the reasons for the knocking, he did ask me to get a highflow and take it back for a re-tune at no extra cost.
R31Nismoid, I got a 38mm external gate setup (Tial gate) and the 3037 has a 0.63rear avo rear housing, and I'm hoping that the cat is the problem behind the knocking, but as for the cold start, I'm hoping he will give it another go and fix that problem too.
The other thing I just remembered is that I dont have an oil catch can, they plumed it back, would this cause any knocking?
It probably wont show much but I added a pic below of the setup.
if it needs 15deg on max load to stop pining some may be wrong
ie cas is off set, base timing is whack, cam gear is whack and so on
check the basics with a timing light
this is a must for anyworkshop
do a base dyno run
check timing
THEN tune and adjust away
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
