OK, so 2 days ago i took my car to the mechanic cos it was overheating, found out it was a water pump, so got that fixed aswell as a new timing chain,air con belt replaced and top chamber of the radiaitor, he took the solinoid out so to order a new one whilst i went to work the next day. Now the car sounded like a WRX from 800 - 1200 rpm, only on idle and when i took off then is fine after that. I drove it to work today cos i needed to, not cos i wanted to and guess what, after 8kms up the road it oveheated. I took it back to the mechanic and he did a pressure test in the radiator and said my head gasket has gone........Have you had problems like the car over heating or anything like that.
Not to say your head gasket has gone but the poping like a wrx from idle to just after i took off i believe could be a timing problem with my car as what i think you are trying to describe.
I could be wrong tho!!!
Edited by Damo_c
I got the same problem it doesn't happen all the time though, it's only once in a while, but it is same as your problem. I think it is a coil pack, best way to find out start the car and just let it idle, pop up your bonnet and pull out the coil packs 1 by 1. So pull the first 1 out and see what the car does if it starts to sound different then it's NOT that 1. So put that 1 back and pull out the next 1, keep doing this until you pull 1 of them out and you see that it's making no difference, because then that means that coil pack is F**ked.
In other words, your car now on idle sounds rough, pull out your coil packs 1 by 1 and put back in. Everytime you pull 1 out it should sound rougher, and if you pull 1 out and it doesn't sound any rougher than that 1 is f**ked. By the way if it does that at more than 1 coil than you could have more than 1 F**ked coil.
Good luck, I hope it's NOT that neway cause coil packs aren't cheap. And I hope that helped
Or rather than trying to remove coil-packs one-by one (when they're bolted together...), you can do a proper power-balance test, as previously mentioned above.
Sorry to sound a little cynical, but we seem to be covering the same ground over & again.
Well sorry but they not bolted TOGATHER on my engine (RB25 NEO). I'm talking about pulling out the coils off from the top of the spark plugs. That takes lituraly 2 seconds. It's worth a try.
I had a similar issue with my beema; would run on 5 cylinders on startup and low revs but once driving, the car came to life again.....tried the coilpack pull out thing and found which one was faulty so i replaced them all and the problem was fixed.
i hope this is the problem....goodluck
If you have an RB engine with multiple coil packs, and it's mis-firing on idle, it's pretty easy and quick to Id the cylinder at fault (if it's a constant cylinder problem, and not switching).
Remove the coil cover, start up the engine, and as it's idling and mis-firing, remove 1 coil loom plug and wait 10 seconds. If the engine gets worse, or stalls, then replace the loom, start the engine and move on to the next loomplug.
Repeat the above until you find that plugging in or removing the coil plug makes absolutely no difference to the running of the engine, and you have found the cylinder that is not firing, or firing only on occasions.
Logic behind it:
you have a 6 cylinder engine which is only running on 5 cylinders (for logic sake, cylinder 2 is the problem).
You start the engine, you can hear it mis-firing, you remove the coil pack for cylinder 1, it gets worse (because now it's trying to be a CA and run on 4 cylinders).
You plug cylinder 1 in, start the engine, remove the plug for cylinder 2, but it makes no difference. This is because cylinder 2 is not working anyway, so plugged in, or unplugged, it's not firing.
Continuing to 3, 4, 5, or 6 wont matter, you have found the problem, and continuing will result in the same as Cylinder 1 anyway.
B.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
