Had my car do a power run on a dyno yesterday, was free so thought why not. However the dyno sheet had a steavy curve upwards but then hit a flat spot and literally was a straight line and then back up, it sounded like it was running excessively rich as well at that point in time (almost sounded like it was bogging down).
The dyno print out gave me 240hp at the wheels and the AFR's were at around 14-15 when boosting. the highest they reached were 15.25. which from what i understand is fairly high.
The mods i have are as follows:
FMIC
10 Psi Boost
Pod
3.5" exhaust turbo back
just the basics.
I know without a decent a/m computer there is not much i can do however i would like some feedback from some of the more knowledged users such as r31 nismoid etc.
Just want a straight forward answer on how to fix these problems and have my car running close to 300hp at the wheels.
https://www.sau.com.au/forums/topic/265910-had-my-car-dyno-tested/
if you are hitting 14-15 afrs when on boost \ full load, please stop driving the car and fix whatever the problem is.
If you don't, you're engine is going to go bang, and very VERY soon.
They should be below 12:1 for safe operation under full load.
You may have a stuffed fuel pump.
+1 on stuffed fuel pump. Exactly the problem i had with mine....stuffed AFM didnt help either when the aftermarket piggyback ECU was pulled out, cos all of a sudden the car was playing up, but before that fuel pump was dead from 4000rpm on, & i hit over 15 for the AFR on the dyno print out as well. As soon as i had a new pump, AFR was around 12 & very happy :blink:
Suddenly made another 20kw at the wheels, even after dropping boost by 5psi.
Edited by cmoney
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
