Hey All!
Have just saved up the cash to finally do the conversion on my N/A R34 and whack a turbo on it.
I know there are threads already open on this topic, but i want the South Aussie opinions on the cost of parts, where to get them, places to get it done and other general info that will help me along the way.
I've called Boostworx like 4 times and they still havent gotten back to me regarding part costs and labour charges.
So if i can get some figures together and work around that then my faith will be restored in the idea of doing this!
Any feedback would be greatly appreciated.
Cheers! :blink:
https://www.sau.com.au/forums/topic/265920-turboing-na-r34-neo6/
Sorry mate, it is a shocking idea. Sell the car and buy a GTT. The costs you come across to do the whole package are staggering, and you will NEVER get it engineered and through Regency.
There is a very simple reason why almost no-one does it - the lengths you need to go to to do it is simply nonviable (have you thought about the need to change your rotors/calipers/brakes, transmission {which is not built to take the power} and your diff {also not built to take the power}).
Agreed. Cut your losses, sell the N/A and just buy a turbo one that came like it from factory, you might even get some goodies on it :blink: By the time you spend the cash to make it all legal it will end up costing you a LOT more than you had originally allowed for
I don't know what the compression is on the N/A engine, but it might be too high to just bolt a turbo on, without having to open up the engine and bring down the compression (change the pistons etc.) not cheap labour wise anyway.. labour is going to be as high, maybe even higher thanthe cost of the parts put together. I think in the end it's cheaper to just sell the current car and get a GT-T
Nah that was just pretty much a quote for the turbo kit and labour. Its the engineering that really has me worried. i get pulled over enough as it is down my way so it just seems pointless for me to go ahead with the conversion.
If anyone is selling a nice stagea....PM ME!
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
