Hey I'm looking at getting some new shoes for my R32GTst
My two choices are below I've also added tyre choices I think might be suitable to make them fit but I'm not 100% sure wether specs exist...
Work CR KAI
F 18x9.5"+20 5/114.3
Tyre 225/45
R 18x9.5"+12 5/114.3
Tyre 245/40
Work XD9
F 18x9.0"+20 5/114.3
Tyre 225/45
R 18x10"+18 5/114.3
Tyre 245/40
At the moment i am running
F: R32 GTR 16x8 +30 235/45
R: Panasport G7 17x9.5 +17 255/40
Ive still got room for growth atm and also wanna go with a stretched tyre setup...
Have adjustable upper arms to increase camber to tuck em in if needed, but if some one with experience can guide me or tell me that this is impossible or possible and what i am overlooking or not
Thanks in advance guy
:blink:
https://www.sau.com.au/forums/topic/265926-help-r32-gtst-new-shoes-dilemma/
I have a 92 r32 gtst, im currently running Black /polished Work XC8's 18x8.5 front at +30 with a 225/40r18 and a 18x9.5 +38 rear with a 255/35R18, I run 2.40 deg neg camber on the rear and with rolled guards i can just get my pinkie between wheel and guard.. Ground clearance is 110mm on car..
I have fitted 18x10 xd9's on the rear with a +38 and they fit ok with the 255 tyre but had to dial in .20 deg more camber.
heres some pics to show you the stance of those on mine..
I can also help you get these wheels as we sell heaps of Work from my shop in Brisbane
Cheers,
Paul
Lenso D1R
F-18x9 + 20 with 225/40
R-18x10+ 20 with 235/40
Sat a little bit mexican but that was with barely any suspension work, just threw the wheels on without adjusting anything.
Rolling on XD9's now with same size just lower offsets and 215's on the fronts
Work CR KAI
Tyre 225/45
Tyre 245/40
Work XD9
Tyre 225/45
R 18x10"+18 5/114.3
Tyre 245/40
:banana:
9.5" wide on the front?? I dont think that will fit at all!
As for the two rim choices, both are very nice - my only issue with xd9's is that they look smaller due to their design.. most of the time 18's look like 17's.
Thanks for all the replys guy please keep them coming.
bros: Paul, ill be in contact with you soon
J-dawg: Jarrad that looks FAT dude, would love to see pics of the new shoes!
r32line: thanks
Below are a few more pics of how it currently sits, Riding on HKS Hiper Damper II Coilovers, JIC shorter upper arms front
on the rears are Panasport G7 17x9.5 +17 with 255 Falken Azenis,
Up front are R32 GTR Stockies 16x6 +30 with 225 Pirelli Dragons
At the back ive got about 3-5mm clearance but its a big tyre,
and up front i have minimum -3deg camber wit at least an inch before wheels goes anywhere near the guard
thanks again
p.s. i know she needs a clean but hey shes a dirty pig!!!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
