Pffft. And There Goes My Turbo
Tangles
 Share
how the hell did you manage to crack that banjo fitting?
lol I have no idea - was tight tight so maybe a pothole?
was all fine until trying to reach boost up expressway hill friday night, couldnt hold 0 psi without the car surging, turbo working on load and black oily smoke
so its split, oil is blowing thru the split onto the outside of the turbo (the leak i found) and forcing some excessive oil thru the exhaust turbine
so it ends up that the slide turbo is ok, but Ive ordered a new line set and a gt30
:dry:
went over the intercooler pipes and they are 100% perfect, good tight seals and wont leak on 1bar
  • Replies 78
Posted Images
http://www.modyourcar.com.au/rb-nissan-spe...ing-turbo-p5224
gt3071r or a gt3076r
6-bolt nissan Rb exhaust housing
$2150 plus lines
getting that sort of deal thru ATS, gave them the $300 worth of gear Id paid for (ceramic ball bearing pack, turbine shaft td05h & 16g.comp.wheel, 2x dead cores and jamesrb25's front/rear housing)
they've take that as the bb-pack and wheels were bnib, credited, and building the GT30r for me with oil line & waterline adapter
2k
so, the turbo is ok to sell. best offer gets it :/
found another source - bongo, fmic pipe, original nissan ribbed black rubber pipe that sat in the chassis hole (in/out engine bay) was splitting
replacing and making good now
waiting on new oil line and GT30
then reinstalling
yeah had a stock rubber black pipe with a split. my bad
got the turbo yesterday, she's beautiful.
awaiting the lovely missus to come back with an 18mm C spanner to finish off the braided lines
then finish hooking her up. no rush just a little steady pace.
garrett core:
ready to go!
MASSIVE THANK YOU goes out to Adam (chef stagea) and Chris (kidafa) for offering to come over and help finish up.
Id arranged an mobile auto bloke to come out tomorrow for an hour or so, but Adam rang me and said he'd help out !
so I knuckled back down and got the turbo oil line on, did the manifold bolts up, got the block oil lead on tight and had a 15' C-spanner cut ready to access the turbo oil feed to tighten it up when the lads arrived.
quick iced coffee / woodstock & a chat and they got into it, wasnt much to be done and an hour later most was all good
dead battery and time constraints for the lads meant we couldnt start her up.
will tick the engine over in an hours time. check for oil/water and thats that
tune time, unless it needs some tightening or reworking, etc
so, cheers for Adam and Chris for their help. greatly appreciated. No knees means my hips and back take the load, and they're rooted atm.
big thankyou guys
where they driving 2 stag's the same colour? a rs4 and a 260?
if so i over took them on the express way this arvo, they were doing 80 in the hundred zone.
did you have a pic of the split cooler pipe?
how big was the split?
Yeah that would have been us in LAZY mode :D
No worries with helping out Brendan. How did it end up? Shoot me a pm with your number so I can save it.
nice
yeah darren the hole in the engine bay airbox area had cut a slice thru the black original silicone joiner, after 12yrs :)
cheers chris, will do. yeah the battery was dead, was charging till 9 last night then went around the block, dumped oil, didnt do up a bolt that holds the stock water line (i took off earlier) onto the block.
heading out right now to grab some more oil, just a small bottle.
then will test again
booked for 2 weeks time for a tune, on the little drive around the block it belt completely different to the other turbo. wow. anyways got2go.
ehhhh does that mean everything needs to come off?
need more hands?
cheers ! nah its all good. will get to it soon and take my time
will need to just take off the intake pipes (2+ turbo air pod feed pipes) and then will be at the bottom of the turbo to take off and replace the split oil return feed rubber line
no biggie, just a fair bit of oil pooling in my garage LOL
>_<
got my sons birthday bbq tomorrow, so will undo tonight and hoefully have replaced tomorrow night / sunday.
sigh*
:down:
Good to here Brendan.
Did the intake pipe mod yesterday arvo. Think it made the induction noise less which is weird thought it would be louder with a metal pipe in the intake but its good less attention :D
the turbo is pretty insane
2500rpm and its wanting to get into positive boost, 3000rpm and 10psi is up
3500rpm and 16psi is up
wow
set up the ebc for 13psi and 16psi
just want to be safe with the safc/sitc/remap and so far so good.
running really well and pulls significantly harder than what Id imagined it would.
yeah anytime !!
will be best to wait for next Thurs 21st, dyno tune day :P
but yeah you know where I live c'mon over ;)
my guess is 220kilobums atm, so surely she'll crack 240kw on the dyno, 250kw perhaps if i bolt on the extra injectors/controller
damn tho, she's fine. time for a drive..... again.... :no:
 Share
    • Yes, it's similar length.
    • Is the CD009 similar length from bell to shifter?    car will just be for the street with the odd track day. It’s RB30det, and weighs about 1000kg
    • The r34 gearbox is like $3400/3700 landed from Japan sometime last year.   Contact jessestreeter.com for info and quotes. From memory the navara gearbox needs input shaft machined down as I looked into a while back and there's a thread somewhere here from 2018-2021 about it. Depends on what your doing with the car maybe worth the dollars to go cd009 or a 8hp50/70.
    • VCAM doesn't really increase peak power, it just widens the powerband. So if you were giving up power with adjustable cam gears to get better low-end response yes in theory it "increases power" but otherwise not really. Stroker kit might put you in a more efficient region of the compressor map which will get you more power but at say 7000 rpm I'm not sure that much will change. The original HKS GT2530, -5s, and GTX2860R gen 2 are all roughly the same kind of turbo. If you want 600 horsepower those are the turbos you need. So 500 whp. Just expect to spend some quality time trying to figure out intake/exhaust piping. The "twin turbo" pipe is an obvious place to start. Make sure the actuator preload and all of that fun boring stuff is set up correctly. Throw a VCAM step 2 at it if you want good response, 2.8L stroker too. If you're not actually wedded to 500 whp all the time you can barely get there with -7s or Nismo R3 turbos, you just have to run E85 or race gas and run them hard:
