  • Replies 78
Posted Images
the turbo is pretty insane
2500rpm and its wanting to get into positive boost, 3000rpm and 10psi is up
3500rpm and 16psi is up
wow
set up the ebc for 13psi and 16psi
just want to be safe with the safc/sitc/remap and so far so good.
running really well and pulls significantly harder than what Id imagined it would.
are you running a aftermarket computer?????
standard computer just tweaking his SAFC and SITC
With that turbo you will max out your standard AFM under 1BAR and you will also run out of adjustment with your SAFC once you fit the bigger AFM and injectors you will need to get anything like the most out of it, after all it is rated to 460hp
Edited by D_Stirls
i think you will find that he has been mislead to a certain degree and its nothing more the a bb high flow.
it certainly isnt the same as the graph you have posted due to the nissan front and rear housings been used.
that graph is for a complete gt30 with garret front and rear.
as DP03 mentioned in FI its not a true gt30 core cause it has a 7 / 14 comp wheel,
thats why i was curious as to what the id tag says.
ID tag was posted in that FI thread.
Front nissan housing and perhaps AVO .63 rear housing?
fact is Im happy with the bolt on turbo upgrade. definitely a top turbo
garrett plate:
IMM 120880
700177-3013
talking to discopotatoe via pm turns out its a GT30 / T04S 60T cartridge, avo .73 rear housing, ported 45v4 front housing
http://www.youtube.com/watch?v=LNQU-tVSuw4
239rwkw
oh yeah
1997 Series 1 Nissan Stagea RS V Four Station Wagon, 106,500kms, Auto, RB25DET engine, Attessa 4wd, Silky Snow Pearl, Dayz bodykit,
Fresh fluid throughout,
Engine:
Ryco Z201 fuel filter, Ryco Z145 oil filter, Ryco Z160 turbo oil filter
Davies Craig automatic transmission oil cooler upgrade kit
MV Automatic shift kit & auto service kit
Koyo Radiator upgrade
Splitfire coil packs
NGK BCPRE6 0.8mm copper v-groove spark plugs
Bosch 040 fuel pump with direct battery feed at 13.8volts
Greddy remote oil filter relocation kit & Fujimoto sump plug drain valve
Garrett turbo oil return filter relocation adapter kit with oil pressure & temperature sensors
Catch can kit
Nismo adjustable fuel pressure regulator
Nismo Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system (turbo to cat)
3inch high-flow metal race cat
3inch cat-back exhaust system with Magnaflow 4" barrel mid-muffler & Kakimoto GTR Racing rear-muffler
Cold Air Radiator air guide (feeds radiator / pod / intercooler)
Cold Air Induction aluminium box w/ lid setup, foam internals, using standard snorkel air feed
Trust 600x400mm FMIC bar & plate, with custom hard pipe kit
Apexi power intake pod filter, with custom hard pipe feed & hard pipe intake to turbo
HKS heavy duty turbo actuator
Garrett GT30/T04S 700177-3 IWBB Turbocharger with ported Nissan 45V4 front / AVO .73 rear housings
Ported & Machined headwork including new valve seals, valve seats and valve guides
EPP Clear camgear timing cover
Cometic gasket kit including rocker cover, intake manifold, intake collector & exhaust gaskets
Cometic head gasket 87mm x1.2mm
ARP head stud kit
Aerospeed adjustable exhaust cam gear pulley wheel
Tomei 256 intake / 256 exhaust poncam gear set
Tomei 8.8mm high lift springs
Tomei oil gallery restrictor
Suspension:
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Whiteline front and rear adjustable swaybars
Dayz adjustable engine swaybar, custom boot swaybar
Whiteline front castor kit
Whiteline rear subframe alignment kit
BJR Graphite 17inch rims with Marshal Mactrac TX tyres, 235/45/17
Brakes:
Maltech stainless steel braided brake lines, front and rear
DBA slotted front brake discs
Benidx Advance front and Heavy Duty rear brake pads
Audio:
Clarion stereo tape unit with 6-stack cd player
Clarion amp mounted to enclosure for Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Razin volt stabiliser kit & car alarm
Interior:
Ghepardo reclining racing seat
Flynn racing seat rail
3x 2" DIN gauge setup including boost pressure, oil pressure & oil temperature
Apexi electronic boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
Greddy Profec-B spec-ii dual stage Electronic Boost Controller, set to 0.9bar and 1.1bar
Toshi ecu remap, tuned by Boostwerx
239rwkw
will get an air/fuel ratio & injector duty update next week
cheers darren, last tune was 206kw so she's gained roughly 17% power
worlds apart in terms of oooomph. gets up 'n boogies
hey CUBES how in the hell are ya ?
great power from the auto for sure, cheers
I reckon I can up the boost, seeing she's got the headgasket etc
1.3bar?
hey dean, yeah no worries, let me know when...
nigel yeah everything is as stock but modified for higher values, ie fueling setup for a big pump, z32 afm written in, airflow values setup for a HKS2540, etc
so yes VCT is working just dandy thank you very much :)
had a quick drive a 3am (couldnt sleep), very very quick :(
