hey
before i take my oil lines off do i then need to drain the car for oil, or can i just take them off. and the water lines do i just take them off to, becourse i have just tried to take the water lines off but there started to come water out, so what do i do.
https://www.sau.com.au/forums/topic/266060-taking-turbo-off/
Hey mate, ive taken my turbo of many times, When you do this its better to drain your oil and radiator in a bucket or so, or you could try n just block the water lines with like a little clotch, as the oil from mine when i was taking of the turbo the oil didnt come out that much.... btw it was for a r33 rb25det , yours is a rb20 .
I did mine in my back yard. I just took everything off and let it fall. taped off all the openings until its time to put it all back together. ill be flushing the coolant system and adding the necessary oil.
