Gearbox
Gearbox cross member (As may be different to auto)
Tailshaft / Front yoke (As may be different to auto)
Speedo cable (As may be different to auto)
New clutch
Flywheel n bolts
Clutch Slave cylinder
Clutch Master cylinder
Clutch fork
Clutch hose (slave cylinder) and pipe from clutch to master cylinder
Pedals both clutch and brake ( auto pedal is to big to fit with clutch)
Manual ECU
Leather gear stick boot and plastic surround
Keep in mind I haven't done it yet...will go in once the VQ is ready.
Ok so i have 2 ways, 1 go manual and use a standalone, 2 install a shift kit and use standalone, i want to know the costs of those 2.. though the 2 requires a rebuilt in the transmition.. Ok i will search for these..
Thank you all!!
You are very quick and full of informations! :thumbsup:
manual conversion then you have to change your wiring. plugs to the ecu wont suit a powerfc or any other standalone. from what i know anyways
Hi all,
I was searching the forum but found nothing that clears what standalone can be used as plug and play to a R34 GT-t with triptronic, can you please help me.. I want to select the right standalone..
Thank you
Akis.
best bet is to remap the std ecu, we do dozens and im sure someone could help you out.
www.nistune.com
  • 3 months later...
Speak to Satanic on here.... Pm him ..... he has a close to 400 rwkw AUTO R34 ...... it runs an F-con pro (i think) ...anyway, it knows when the auto is about to shift and softens up the power to make smoother shifts etc .... best to speak to him, but it works very well.... and you can't dispute close to 400 rwkw !
Gary
  • 2 months later...
Gary
:blush:
Bit of an old thread but....
Haltech and ViPec then work on an auto R34 GT-T? I'm looking at getting a new ECU, tune whatever and wanna keep my auto box. I don't wanna f*ck around with a manual gearbox conversion (not to mention I'll be paying ~$2000 to put R33 parts into my R34), I may aswell sell up and buy something thats manual (from my POV).
However if I build up the Auto box then I can run whatever the hell I want? Apexi, Motec, etc. Whats required in building up the auto and how much will that set me back?
So I believe my options are...
1) Haltech, ViPec, Nistune or E-manage.
2) Build the box up and run whatever ECU I like.
Is this correct? I've done so much searching on the subject my head is spinning!
As covered before, the Haltch and Vipec WON'T run the Auto box, the auto logic is inside the stock ECU. HOWEVER everyone that is saying it will work has probably seen it work on an R33 or similar where the auto logic is controlled externally to the factory ECU, so you can stick a standalone in those cars...NOT the R34 GTT (even the tiptronic R34 25GT will work with standalone, it had to be different)
Nistune is the most simple and effect option, the remaps really are good. I've got a different type of board, but I can play with ever facet of the tune adn retain the factory ECU and shift logic.
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
