  • Replies 46
well good news and bad news.
bad news im calling of the group buy as to the fact the guy who was going to make them for me has pulled out
good news is i will search for a new guy who can do it for the price listed
untill then keep those skylines humming and sorry bout the inconvinience.
cheers
i just saw the price of these kits. wow, that's a lot. i reakon i could easily make kits for about $150 using good quality struts
Can you take over from here?
  • 3 weeks later...
Hey guys lots of cars have gas struts on the bonnets, i bet that there is some car out there that has exactly the right struts and brackets to fit straight onto ours, or maybe with a slight modification. The thing ive noticed is that most bonnets that have gas struts installed are very light flimsy bonnets where ours are quite heavy ..
Are you serious??
33 bonnets are light compared to your typical ford or commodore, also the problem is that most cars have the mount on the side of the bonnet its self, but because skyline bonnets are so thin and flimsy you cant put anything there, the main bracket needed is the one on the hinge, the one on the guard is easy, just use a 90 degree mount off a commodore.
i think its the opposite my r33 gtst bonnet to me seems bulky and seems like it would be heavy, my friends commodore bonnet is that thin it moves while driving .. but everyone is entitled to an opinion im not saying your wrong, its just my opinion, i reckon a mechanic that sees alot of cars would be the best to ask if thyere may be something that could be a close match ..
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
