Stu_R33 Posted April 29, 2009 Share Posted April 29, 2009 OK, interested in the JJR pipe. Would you take $120 cash on pickup? Could probably get there in the next couple of days. If yes, PM some contact details - I can;t send PM, since I've got less than 10 posts... bugger Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4562695 Share on other sites More sharing options...
Truespeed Posted April 29, 2009 Share Posted April 29, 2009 I'm wondering if you have the sensor that goes behind the steering wheel that connects to the steering wheel, they told me it was the srs sensor?? Pm me info and price Got alot of parts for sale which i have accumulated over the years. Everything is in good working order unless stated otherwise. Located in Emerald, Victoria. Photos will be put onto photobucket http://s160.photobucket.com/albums/t177/Shano3000/ will take photos of parts on request aswell. Wrecking complete R33 GTS-T. RB25DET Complete Engine 100,000km. Will include everything minus engine loom. Very good condition with stock turbo. Had its major service 3,000km before crashed. All belts, idler tensioner, water pump etc 3000km old. Was running fine after crash - $2000 Gearbox, good condition - $1300 3,000km old exedy heavy duty clutch - $150 Tailshaft - $150 Diff - $150 3" turbo Back exhaust. Bellmouth dump/front pipe into jasma muffler - $400 FMIC Return flow kit. Includes generic fmic with Blitz return flow piping and all clamps/joiners. No holes need to be cut - $300 Front brakes With rotors and pads. Pads still got plenty left. Good condition - $350 Rear Brakes with rotors and pads. Good condition - $150 2 X Starter motors - $50 each Air Con pump - $50 2 X Gearbox Mounts - $80 each Rear Axels - $50 pair Rear bar painted white. Good condition. Appears to have been re-sprayed - $100 Rear bar Reo - $40 Boot lid with Series 1 spoiler - $50 Tail lights - $50 each undertray stone guard. Has a few small tears - $40 Car mats. Complete set - $50 Drivers side Head light. Off a 4 Door, chrome surround. A little bit yellow. $50 Lots of other parts available. Just let me know what you want and ill get back to you with pics/price. RB30DET Parts: Rb25de non vct head from a R32. Head has been cleaned, new valve stem seals, heavy duty springs for turbo application and surface machined flat. Inlet manifold, injectors and fuel rail, throttle body and all bolts/miscelanious pipes etc - $650 Good Condition S2 RB30 Bottom End, fully assembled. Brought as working motor and stripped head etc off - $75 Rb30 S2 block, disassembled. Includes crank, rods, cradle and block - 6 pack of Bundy New ACL Duralite cast RB30e pistons and rings, 1mm oversize. Suitable for RB30DET conversion. Will give compression of around 8.3-1. $250 New ACL Duraglide engine bearings. to suit RB30. .25mm oversize. includes rod bearings. $50 RB30 complete engine gasket kit with Headgasket. No sump gasket included - $100 RB26 Oil Pump. Came off R32 GTR. $100 RB20DET Exhaust Manifold. Will bolt to Rb25de head. $40 Will post smaller items at buyers expense. Pickup only for gearbox, engine etc unless you organise everything and pick-up from my house. Contact through here, PM, or message/call me on 0422816780. Cheers, Shane. Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4562746 Share on other sites More sharing options...
Shano3000 Posted April 29, 2009 Author Share Posted April 29, 2009 PM Sent Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4563418 Share on other sites More sharing options...
Komdotkom Posted April 29, 2009 Share Posted April 29, 2009 Is the rear subframe and suspension available? Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4563676 Share on other sites More sharing options...
Shano3000 Posted April 29, 2009 Author Share Posted April 29, 2009 Is the rear subframe and suspension available? Yep, everything apart from rear brakes is still available. Cheers Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4563734 Share on other sites More sharing options...
Stu_R33 Posted April 29, 2009 Share Posted April 29, 2009 PM Sent Thanks for that - still can't reply to PM. I'll take the JJR pipe for $140. Can pick up tomorrow evening if that works. Please PM your address and/or number. Thanks Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4563749 Share on other sites More sharing options...
JamesK Posted April 30, 2009 Share Posted April 30, 2009 Ariel & Rear skyline Facia available? if so how much?? Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4565300 Share on other sites More sharing options...
Shano3000 Posted April 30, 2009 Author Share Posted April 30, 2009 Ariel & Rear skyline Facia available? if so how much?? Sorry mate both gone allready. Dump Pipe - Sold Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4565897 Share on other sites More sharing options...
Shano3000 Posted May 3, 2009 Author Share Posted May 3, 2009 SOLD: RB30 Package Gearbox Engine Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4571198 Share on other sites More sharing options...
Shano3000 Posted May 6, 2009 Author Share Posted May 6, 2009 Clutch - SOLD Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4578295 Share on other sites More sharing options...
Robo's Posted May 6, 2009 Share Posted May 6, 2009 Do you have a power window module located in the drivers door? Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4578573 Share on other sites More sharing options...
chinii Posted May 21, 2009 Share Posted May 21, 2009 do u still have the right side head light ? and will it fit a 2 door? thanks Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4609261 Share on other sites More sharing options...
Keeffy Posted May 21, 2009 Share Posted May 21, 2009 Rear bar painted white. Good condition. Appears to have been re-sprayed - $100undertray stone guard. Has a few small tears - $40 Hey Mate do you still have these available? Can i get some pics of the rear bar, do series 1 rear bars fit series 2? Cheers Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4609323 Share on other sites More sharing options...
W0rp3D Posted June 5, 2009 Share Posted June 5, 2009 What condition are the starter motors in, have you used them? Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4639611 Share on other sites More sharing options...
hawtwax Posted June 5, 2009 Share Posted June 5, 2009 hey mate do u have a drivers side wing mirror? and do you know if the series 1 mirrors match series 2? cheers Link to comment https://www.sau.com.au/forums/topic/266117-wrecking-1994-r33-gts-t-victoria/page/3/#findComment-4639888 Share on other sites More sharing options...
