hey all got my 4wd up for sale was using it to get my moto x bike around but i don't need it any more as after i'm finished with the ceffy ill be buying a ss ute
86 nissan 720 4X4 dual cab ute
2.5 lt diesel 4 cy
man 5 speed
cb radio
goes great runs like a dream
has a stezza and speakers and upgraded front seats (heaps comfier than the standard junkers)
has sunraysia rims on it with good tires
has a tow pack on it
has bull bar and side rails/steps
would be perfect for towing a drift car or your moto x bike out to the track
heavy duty deep cell battery
will come with 3 months rego at that price
needs a new alternator i was quoted 270 bucks for a new one but a recond one would be less
located in sa
price $1200
Edited by a31lunacy
https://www.sau.com.au/forums/topic/266135-86-nissan-720-dual-cab-4x4-ute-man/
2.5 lt diesel 4 cy
man 5 speed
cb radio
located in sa
price $1200
sent you a meesage got a mate keen to check it out in adelaide.
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
