Is it just me or do the new members appear dumb these days...
No its not just you. Someones certainly been peeing in the gene pool.
Lads, the law says you cant play with your stuff or you'll go blind.
Just do as they say, we already get pulled over and defected for non-existant bov's why give the cop an excuse to fine you for a fart cannon or a body kit?
Wait til you get off your p's, mature a little and realise that its not all about big rims, loud exhausts and hectic body kits.
if the cops in VIC are anything like the ones in NSW....
do your standard engine internal mods...they wont know shit....but stay away from anything that might make a whole lot of noice or would stand out when they pop the bonnet ie, intake, exhaust etc etc... but skylines tend to get alot of attention from cops....expecialy when you have a P plate on the back
Look, let me say this: The P-plater laws have been around for years and have been tightened up in the last 2. Do your research and you'll find out all the information about these laws.
However, in general, if I was on my P's, I'd avoid doing anything to the car that would attract attention, i.e. adding wings, a big bodykit etc as to the average cop, if your car LOOKS FAST, it probably is and therefore you become a TARGET.
It's like driving around if a BULL'S EYE on the back of your car. I hope this answers your question. Up to you if you want to attract more attention for a Skyline as bad as it is already.
    • I also understand psi but apparently most things make more sense in kpa oil pressure being one of a few exceptions so im trying to learn ahahahah, I have no idea of the relief spring pressure tbh I thought 110 which is the absolute peak it hits was about right, I was thinking of removing the relief and making sure it is in good condition, I would just replace it but couldn't find a replacement for an n1 pump too easily but I could just be blind.
    • It certainly does make sense that there is just no oil to pick up, but I can go 3 or 4 gears of WOT and have no oil pressure issues too (I have no logs of this unfortunately) and I have a fair amount of oiling mods to try and help only thing I'm missing is a rear head drain which is potentially the most helpful.
    • speaking of the relief spring and noting this is one of those stupid times where I understand imperial (psi) but the graph is in metric (kpa), it looks like the oil pressure is a little low at full noise too, isn't the relief spring 120psi/830kpa?
    • No. All these dirty old Datsuns are shitboxes. Including the GTR.
    • Yeah well I was thinking...there is nothing that happens when you get off the throttle that should cause low oil pressure, its not like clearances suddenly change or and the relief spring would close and in any case the sensor is on the feed side....so more likely there was no oil available to pick up which means all the basic oil control stuff to: 1. keep oil out of the head (restrictors) 2. get it back out of the head when it gets there (external breathers/oil return, drilling out the block and head oil returns) 3. have more oil in the sump to pick up - larger capacity sump 4. have more oil near the pick up - baffles
