Hey all
normally i wouldnt post something like this, but i know some of you may know what the deal is with changing from side feed injectors to top feed? has anyone in sa actually done it?
whatsisname is the man to ask! but i thought neo 6 were top fed anyway?
but it is more costly changing to top fed because you need to get a fuel rail made! but i went for it because i thought maybe later on i might need to go for bigger injectors and there is a bigger variety of top fed then side fed
Edited by nos man
i need 1000cc injectors and i cant find any for the RB25
the other option i was thinking was maybe going with RB26 fuel injectors and getting a RB26 Fuel Rail to match but i dunno if that will work either!
1000cc are pretty big injectors! aiming for huge numbers or something?
but rb26 injectors should fit into neo 6 motors! no need for fuel rail i don't think but they're like 440-480cc injectors?
edit. rb25 neo, rb20 and rb26's all run top fed injectors! it's the r33 rb25 that runs side fed
Edited by nos man
I got 870cc Bosch Siemens Injectors forsale. $600
Came out Phu's old 34 im pretty sure.
Edit, 34's are top feed anyways.
Edited by Luke_ENR34
yeah the supercharger im getting is 800 hp with a 1200 CFM on it :thumbsup:
are you taking the piss Cara or you are seriously thinking of putting a 800 hp super charger on your car?
ive seen you drive NA and i can asure you with anything over 300 hp you will become a statistic.
please be careful.
RB25 NEO's run top feed high impedance injectors. i would suggest wiring in a resistor pack from a GTR and running low impedance injectors for a couple reasons. Because the injectors you use will then be the same as the GTR injectors there was more of a market than the high impedance injectors used on the RB20's and therefore should be slighly cheaper. Also low impedance injectors are a lot easier to control when running low duty cycles.
If you are going to be making 800hp then you will need to run an after market rail (probably 14mm injectors as well) and you will have to upgrade your fuel lines from the tank, it'll be expensive but i'm sure you weren't expecting it to be cheap.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
