Hey all
normally i wouldnt post something like this, but i know some of you may know what the deal is with changing from side feed injectors to top feed? has anyone in sa actually done it?
whatsisname is the man to ask! but i thought neo 6 were top fed anyway?
but it is more costly changing to top fed because you need to get a fuel rail made! but i went for it because i thought maybe later on i might need to go for bigger injectors and there is a bigger variety of top fed then side fed
Edited by nos man
i need 1000cc injectors and i cant find any for the RB25
the other option i was thinking was maybe going with RB26 fuel injectors and getting a RB26 Fuel Rail to match but i dunno if that will work either!
1000cc are pretty big injectors! aiming for huge numbers or something?
but rb26 injectors should fit into neo 6 motors! no need for fuel rail i don't think but they're like 440-480cc injectors?
edit. rb25 neo, rb20 and rb26's all run top fed injectors! it's the r33 rb25 that runs side fed
Edited by nos man
I got 870cc Bosch Siemens Injectors forsale. $600
Came out Phu's old 34 im pretty sure.
Edit, 34's are top feed anyways.
Edited by Luke_ENR34
yeah the supercharger im getting is 800 hp with a 1200 CFM on it :thumbsup:
are you taking the piss Cara or you are seriously thinking of putting a 800 hp super charger on your car?
ive seen you drive NA and i can asure you with anything over 300 hp you will become a statistic.
please be careful.
RB25 NEO's run top feed high impedance injectors. i would suggest wiring in a resistor pack from a GTR and running low impedance injectors for a couple reasons. Because the injectors you use will then be the same as the GTR injectors there was more of a market than the high impedance injectors used on the RB20's and therefore should be slighly cheaper. Also low impedance injectors are a lot easier to control when running low duty cycles.
If you are going to be making 800hp then you will need to run an after market rail (probably 14mm injectors as well) and you will have to upgrade your fuel lines from the tank, it'll be expensive but i'm sure you weren't expecting it to be cheap.
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
