yeh mate unfortunate but true
came in like a year and a half or so ago - so if u didnt get your licence before then - no turbos for 3years
(cept turbo diesel - if thats your thing)
i was lucky XD
Which rock did you crawl out from?
Adelaide
and you may have a chance of an exception if you owned the car and moved as in Adelaide if i remember they dint have turbo laws or is that WA
If you owned your provisional license before July 2008 your all set. after then, your screwed as you will be put on to p1 or p2 (turbo and 8cyl restriction, as well as late night restrictions as far as passengers). Speaking as a current provisional license turbo car owner.... :wacko:
ok well that sucks i might just keep it registered here and and keep my south australian license until its full, yeah south australia doesnt have any turbo laws we dont even have RWC's or anything like that, just trying to get my head around it all think best option is to keep a P.O box in S.A somewhere and leave it registered here
If you owned your provisional license before July 2008 your all set. after then, your screwed as you will be put on to p1 or p2 (turbo and 8cyl restriction, as well as late night restrictions as far as passengers). Speaking as a current provisional license turbo car owner.... :P
I got through on the Pre-July 2008 rule :wub: I was previously on a P1 in NSW so there's a double benefit for me.
When did you own the car? If you've owned and continue to own the vehicle before 30 June 2007, then you're in!
Here's a few fact sheets and links that should have most of the definitive answers, if that doesn't answer your question then contact QT, though applying for an exemption would probably end up being the way to go.
http://www.transport.qld.gov.au/resources/...ns_brochure.pdf
http://www.transport.qld.gov.au/resources/...provisional.pdf
http://www.transport.qld.gov.au/Home/Licen...le_restriction/
I got through on the Pre-July 2008 rule :banana: I was previously on a P1 in NSW so there's a double benefit for me.
cheers heaps for that info, na havent owned it since then however i think i will just keep my license and car registered here in SA
If you owned your provisional license before July 2008 your all set. after then, your screwed as you will be put on to p1 or p2 (turbo and 8cyl restriction, as well as late night restrictions as far as passengers). Speaking as a current provisional license turbo car owner.... :banana:
lol i've actually had my provisional license since 2003 my own fault for being an idiot on the roads though
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
