  • Replies 356
Fresh update yet again!
  • GoldZilla; Nick; C34; Toongabbie; any day except Thursday night
  • Daleo, Dale, NM35, Emu Plains, Depends on the week, (Shiftworker)
  • Jetwreck, Craig, MN35 AR-X, Westleigh, Not Wednesday, Not at weeknight for the next 2 weeks, depends on soccer for the day on the weekend.
  • Bis-e Bee; Stephen; NM35; Blacktown; anytime, anyplace! :laugh:
  • Andy65b; Andy; NM35 AR-X; West Ryde; Not Thursday, Weekend in the afternoon, not this weekend.
  • ZEi250T, Iain, NM35 RX, Eastwooooooo, Whenever, wherever if the moneys right
  • Danny NM35 ARX glenorie, wat eve suits every1 :laugh: im pretty flexible cuz i aint married :banana:
  • Paramour, Julius, M35 AXIS, Northern Beaches, Sat night, anytime sunday
  • Crisis; Michael; ARX; Wahroonga; flexible
  • mxfly; Eugene; M35 AR-X; Wahroonga; anytime really.
  • CL11QE; Alex; C34; Riverstone; flexible
  • alu-siv_stagea, eddie, 99 rs four, botany, weekends (sunday better)
  • Charlie Stokes; C34; location unknown; flexible
  • CoastalChill/fat-lad; Kacey & Luke; C34; Newcastle; Sunday afternoon (someone suggested 4pm) sounds great!
  • inmate; John; C34; Blacktown; flexible
  • gebba54; Gerard; C34; Sutherland; Sundays preferred
  • too_much_boost; Anthony; location unknown; keen depending on time and location
  • Bikenut; Murray; M35 ARX; Helensburgh
  • StageIan; Ian; 99 RS4; Toongabbie; date as set
  • mike40sydney; Mike; C34 s2; Hassall Grove; date as set.
  • Angus Smart; Andrew; M35; location unknown; date as set, as long as the car is ready.
  • stagmeister; Jimmy; C34; "Western Sydney;" date as set, as long as the car is ready.
I'm rrrreeeaaalllllyyy looking forward to this!
Ben from North Shore Prestige may also be able to attend with a Stagea we may be interested to see.
Not definate yet but he is interested.
Cheers
Andy
lol... You going all "Danny" on us Andy?
Or do you only tell the people that definitely won't be there?
It's interesting but not that special. We spoke about it the other day. It will have trade plates.
Yes I know. But I figured those who do not know already may want to know.
So it is done?
Edited by iamhe77
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
