  • Replies 356
I can organize a car-park/location down the end of Leeds street in Rhodes after hours if we need a venue.
just an FYI though...if FW's start doing heli's or stupid shit it will stuff it for us all.
Agreed, that is something I would expect from say the Sydney WRX or Silvia club or even the Ford/Holden creatures. . . . .
Stagea owners are more refined, stylish and classy. . . . . M35 Owners more so. . . :)
Jules
my insurance company (ex insurance company) said too many claims are being made on Stagea's. Has to be the C34's as I have not heard of any M35's having bingles. And we are all too sensible to do that.
Maybe not Jetwreck with his 17 year old mental state :)
Only two sleeps to go.. :)
Then I will be a NSW M35 owner for about 12 hours...
Then I will the other VIC M35 owner on the forum...
Should mention, that I did see a M35, not blue in colour, past Fountain Gate the other week... so there are more out there..
Haha! Now only 1 Sleep!!!
and you don't have to worry about the exhaust pickup either.
Your M35 better be available for a viewing this weekend mate :)
I have seen other M35's around including the one you are referring to.
Unfortunately 2 of the 4 I have seen (other one is near Geelong, there is also one up towards Ballarat) are owned by me and my mate :D
Location is Rhodes is pretty much OK to go. I also have another industrial location thats private property in Buffalo RD in Gladesville we can use.....owner has OK'd it.
Just need dates and time people.
P.S. I have an excellent place for Photo's Rhodes at the moment...our empty warehouse!!!
an empty warehouse sounds great to me, regardless of weather etc. we would be able to pop bonnets and do comparisons etc etc.
All in the safety of a secured venue so no passers by start sticking noses in etc. where they are not wanted.
I give a thumbs up to this idea, nice one Jet!
Rhodes works well for me. . . . Sunday would be even better
Jules
I've no objection to it being a Sunday, probably a bit better than doing it of an evening.
What's everyone else think?
I could probably do either a week night or the Sunday but would have to be an afternoon. But I know I am away from Sunday 2nd till the 5th May.
Cheers
Andy
Seeming as though Jet is kindly providing the (possible) venue, I think it would be nice to wait for 3 weeks or so until his beast is back on the road.
Plus I really want to see the high flow job he done on it :D
I'm sure a few of you other petrol heads wouldn't mind checking out the work that has been done to it.
very much agreed, so if Jet provides a venue and date then we all can start to plan. .
Edited by Paramour
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
