Boss Automotive is another place as they are the diff specialist
+1, I had my r31 fitted with an LSD made by Boss and it was awesome. Wasnt cheap because I went all out but it was damn good...
-D
i am in the mist of looking at getting my r33's diff shimmed
got a quote of like $600 for removal, shimming and re fitting the diff
which i dont think its over the top as they are the speciallist in it and from memory they were going to be replacing the bearings as well
A shimm diff it basically a locker
Also shimms wear down unlike welding... which break :wacko:
I reckon 1.5 or 2way LSD is the way (orrrr the welder)
1.5 is more streetable
2way is a bit iffy, depends where, when how you drive
I shimmed mine LSD. Was tight as a b!tch, great to have 150% locked. Saying that though, one day through marion car park reversing out a car park..... f**king BANG :D ..... it broke.
It impresses da chickz uleh
-D
HAHAH yeah it like
Hey uleh... Look at me!
Ehh Ehh Ehh Ehh Ehh Ehh Ehh (trying to do a U-turn)
LOL Shimms r fun but wear down over time and need adjusting
Check out http://www.skylinesaustralia.com/forums/Di...Gt-t164288.html
Edited by MYCEF3
Just remember, more tractive force from the diff center puts a lot more load on drive shafts, cv joints and bearings. As well as on the rest of the drive train and mounts.
Edited by Jamesrb25
I will shim peoples diffs for $250 + you supply the oil and gasket if needed (HICAS diffs a little extra unless you pull it out). People can also came and watch while I do it and that way they can learn how it is done them selves. This is handy because as people have mentioned above they will wear so after a couple of years they will need to be done again.
What people are saying about a shimmed diff's being a locker isn't necessarily true. You can shim then to be a locker but if you select the right shim it will just be a really tight V-LSD and it won't skip. Also the Shimming is preloading the viscus cuplink and isn't actually changing the back lash, the bearing shims do this not the cuplink shims.
Edited by D_Stirls
i found a bit over 3mm (over both sides) was best for me, i recently just chucked in 2x 1.6mm ones in over the top of the standard ones, locked her up good and tight lol
just be careful, if u go too thick like i did, it wont fit in the housing anymore, i had to create custom bearing shims (thinner) so it fit in lol.
please correct me if i'm wrong, but i believe my diff is the same as S15 (Helical diff) not viscous
am i still able to shimm this diff? i'm intending to use this for drift, only until i can afford a 2 way LSD
looks pretty easy to do DIY
cheers for the help guys, and keep the constructive criticism coming :woot:
    • Regardless, its peace of mind swapping the factory twins for something else. Personally if it was me: Link G4X Additional sensors for engine protection Twins Oil pump mods(maybe throw extension to sump) injectors/Pump Clutch Exhaust Oil Cooler Good pads/suspension Should be good for 3-350kw depending. Granted thats closer to 15k but still.
    • I think you are over thinking it again
    • My R33 never ran more than stock boost but it was unclear whether the turbos would last. Maybe OP's car is less of a question mark but for my stock turbos had over 175k km on them + 25 years of use. That's a very long time to hope nobody has ever accidentally put physical shock through them, no debris in the exhaust gas stream, no boost leaks that could cause the compressor to spin faster than it otherwise should, no oil coking in the journals, no wear scars for any reason, etc. You could pull the turbos and disassemble to inspect/overhaul as needed but for that kind of effort you may as well replace the ceramic turbine with something that can take a bit more abuse no matter what you find in there. Stock boost ceramic turbos really don't make that much power either.
    • A Pillar forward?   The part above I was just looking at was the reo bar, I'd replace it, UNLESS the panel beater is GOOD. From your early photos, it did look like the chassis might be tweaked, or at the very least there was tweaks in radiator support. I'd personally do a new / second hand unmolested reo bar, and drill it, only so I know underneath the pretty painted front bar, there's not a mess of other metal that's been hit and smacked.
    • Yes no yes. Pineapple rings do do a certain amount of subframe "locking up", in that they do add some resistance to lateral movements. But the primary reason they exist is to alter the driveline angle. Depending on how you install them you can either increase or decrease rear traction __ a little bit __ by changing the angle of the lower control arms relative to the car/pinion angle. The thing is, given what they are, how and where they are installed, their lack of engagement with anything in particular, there's a limit to how much benefit they can offer. The GKTech collars put metal into the space in the stock format bushes, thereby limiting how much give they have. The rubber is still there to take up some force, albeit perhaps preloaded a little by having some extra metal jammed up into it, but the increase in stiffness comes from making it so that the stock format bush can't deflect that large bit of rubber over into the space adjacent to it, in any direction. Top AND bottom. Which the pineapples certainly do not do. As I said in my other thread - I'm convinced.
