Looking at buying a HKS Type-1 TT...buy price approx $340... Is this a wise move?...or for the cash should I look at another timer?
Also looking at buying a 5"Tach (Autometer/Autogauge). Nothing too flash...the one i'm looking that's $300. Should I steer clear of the cheaper gauges and wait for something more reputable?:confused:
Advice / opinions
https://www.sau.com.au/forums/topic/2663-timers-tachs/
340 for a turbo timer, ouch.
I think you should buy a cheaper turbo timer.. 100-150$ and get a better tacho, those autogage series are very budget looking although im sure they perform the same as the more expensive ones, they just dont have a u beaut silver surround and face.
Shaun
https://www.sau.com.au/forums/topic/2663-timers-tachs/#findComment-48025
well in that case, i would be about 80/20 in favour of buying it.... as for the monster tacho, i guess its just personal preference, same as brand... all aftermarket gauges that i bought are all autometer and ivee had nothing wrong with them... damn those jap brand ones are damn expensive!!
https://www.sau.com.au/forums/topic/2663-timers-tachs/#findComment-48681
Sweeet....I'll get the TT when I get back to Brissy:D ...Then ponder the Tach a pay or 2 after that...really all I want is a shift light ($20 compared to $300). I would go for the shift light on its own if it was readily adjustable...can this be one without too much hassle???:confused:
https://www.sau.com.au/forums/topic/2663-timers-tachs/#findComment-51163
Monster tacho in the middle of the dash in an R23 looks sshhhweeettttt :uh-huh:
Otherwise brands like Pivot and Autometer make individual shift light units, I know the autometer ones are still fairly dear though and they take RPM catridges to set the shift point. The Pivot unit looks cool and from memory you can dial in the shift point which is easier.
Nick
https://www.sau.com.au/forums/topic/2663-timers-tachs/#findComment-51167
I know!!! when I went-a-lookin' the guy at the shop had an open one...I didn't think it'd fit ('cause I wanted to mount it on the R/S of the dash) and so he pulled it out - it looked terrible. So I went on looking for places to sit it and the middle of the dash was the sweeetest option...:D
https://www.sau.com.au/forums/topic/2663-timers-tachs/#findComment-51171
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
