ive got a r34 gtt rb25 neo
well im almost done buying up all my mods and then i stumbled upon PONCAMS...tomei 260's with 9.15mm lift.
now ive got a hks 2835 pro s kit internal gated with all supporting mods.
will this turbo im using require the investment of poncams for track days and or 1/4 mile time differences or will it just be a waste of money?
mind you its my weekender and will only see track days a few days in a year...must have driveability as i will mostly be streeting it and dont want it driving like a dog...plus will the 260 poncams give me more lag on the hks 2835 pro s?
so should i poncam or not poncam???
any advice or prior figures to help would be great..thanks in advance.
on the S2 stagea they made more power everywhere so IMO they are a good thing but keep in mind that valve clearances will need to be checked and possibly require re-shimming. there were no losses down low just more grunt everywhere.
the time and cost might make it a lot more expensive than you expect so with a great turbo like you have on the way i would go ahead and install it without cams unless you can get the cams for a stupidly cheap price.
bass junky and abo bob have threads on this if you search.
yes ive searched but always open to people opinions and maybe someone had some new light to shed.
so more power everywhere but at the same time its not justifiable for $$$ to kw value is that what your saying?
i know that it will make more power up top but im definately not wanting to lose any power down low or cause more lag.
also what exactly are shims? sorry not full aware of how they affect cams and if need be how much will it cost to re-shim if you know?
my car and bombtracks have the same mods, his with poncams, mine without
he gets 275 rwkw on PULP, i get 270
I get full boost a few hundred revs earlier
so am i following this right, bombtracks got poncams 275 rwkw with more lag
and you joeyjoe have 270 rwkw with less lag?
correct??
correct....
in a real world environment stock cams ramp up more quickly. albeit only a few hundred rpm
on a dyno sheet the poncams dont look like they lose anything down low, because you sit in 4th @ a couple of thou and the cams are already starting to breathe before the pull has started, so they are on song right from the start of the curve.
in the real world you are changing gears all the time and launching etc and the controlled dyno curve never happens
poncams are a waste of money imho.
you have the same turbo setup as me, spend the money on a datalogit box instead and run e85, $600 delivered and i now have 311rwkw with full boost just before 3500
Cams are always worth it. It's basically like making your head artificially breath more. I think of it as a cheaper alternative then a port and polish to gain more head flow.
That sounds f**ked up. Were the cams dialled in properly with adjustable cam gears?
I have always gained power right through the rev range when upgrading cams. I made an extra 7rwkw peak but had another 21rwkw of midrage from 3500.
This is all relative too... depends on the turbo you are running too, a turbo thats maxxed out with lots of turbine inlet pressure can cause larger cams to drop power.
Edited by Fastrotor
that's the turbo we are talking about...
same tuner, same dyno
both cars run a greddy rb26 ex cam gear and the cams were dialed in properly
tuner is rob @ created
i was speaking to ben from racepace a little while ago and he was telling me nit to go for cams, citing the reason i stated earlier.
he was saying that with many of his customers track cars he returns them to stock cams and sees an improvement in lap times,
This is JJJ's dyno sheet from the first tune:
http://i295.photobucket.com/albums/mm144/h...n/dynosheet.jpg
This is mine:
http://img293.imageshack.us/img293/4052/ji...ismdyno2qj4.jpg
This is a fairer comparison between our tunes as Rob hasn't had a chance to fix my inj. latency's or shim the cams properly. JJJ is now running 270rwkw after a second tune. I am expecting a slight increase in power after my second creatd tune for the reasons mentioned before.
I am yet to be convinced about poncams one way or the other but what I can say is that at our power level, there may be a difference in amount and delivery but it's f**k all.
Cheers.
having looked at both graphs it looks like it takes more boost to make similar power.
this doesn't prove one way or the other that cams are good value cost/benefit but it seems cams make it breath better.
i don't have back to back dyno prints +/- the cams but on the stagea, i was concerned it would lose down low but the car was better everywhere on the road. with a big heavy lump like a stagea carrying an extra 350-400kg it was a genuine concern if we lost down low and we didn't.
since there are so many variables with cars, engine condition, temperature, fuel, tuning etc it is hard to get quality back to back testing on a single car let alone comparing two different cars.
I don't disagree with you at all. I don't have good enough evidence to suggest one way or the other. All I know is that cams did NOT hurt performance and in fact gave a little extra (ON PAPER), so why not!? :)
yeah i can vouch for the Stagea working well with poncams (non-neo)
simply feels like a 3litre.
upgrading my turbo right atm, my slide highflow is off and putting a GT3071r on
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
    • Try fabricating something like this and install it under the pedals? Not sure if it's legal or not....
    • Even though I have some pretty good (brand) ratchet ringies, I avoid using them to break open tight bolts. A broken ratchet is very annoying.
