umm mines a GTS, so it idels at 500 rpm, around 1000 with aircon and demist on.
I use BP Ultimate. I tired Optimax, but my exhaust kept givin off this godawful sulphur smell.
BTW b4 u post athread next time, search there's been about 6 threads already and 1 poll about which fuel ppl use.
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-562770
I have only, do only and will only ever, use Mobil Synergy 8000. Sure it gets a little pricey sometimes but someone once told me that was the one to use for my Skyline. And when he talks Liners, I listen.
I think it all comes down to preference tho. I'm not sure there is a "perfect" fuel to use.
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-562976
I was reading a big write up on the quality of fuels in Australia and it had some VERY interesting info in it. Personally I only user Optimax but once my new car arrives I wont be using it anymore. It turns out of Vortex, Optimax, BP Ultimate and Synergy 8000 that only two of these fuels have a true 98RON level - Optimax and BP Ultimate. It is even stated on Mobil and Caltex's web sites that their high grade fuel ranges between 95 to 97 and that’s piss poor!
Another thing I found was that BP Ultimate is a higher grade fuel than Optimax due to the fact they add additives to Optimax to get it high octane levels where as BP is brewed that way and has less aromatics than Optimax. Interesting hey!
As for higher grade fuels - Elf LMS. This stuff is shit hot and can provide up to a 30rwk gain in power in cars like Skylines etc. LMS is available in either 200 liter or 50 liter drums. Price: $4.85 per liter (200litre drum), $5.30 per liter (50litre drum).
As LMS is an unleaded fuel, no CAMS license is required to purchase the fuel only problem is as you can see it’s pricey but well worth it for a day at the drags. Should get a few runs with a 50 liter drum :P
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563224
some of the 'better' octane boosters do provide up to 2.0 points increase. Nulon Pro Strength gave I think about 1.7 in a HPI test a couple of years back and for about $12-15 was the best buy in that dept [octane booster dept].
Adz: Strangely enough I think I find Synergy gives me a smoother idle than BP...strange.
Ward: in terms of price I dont find synergy any dearer than ultimate in my area, they are both around 7 cents dearer than regular unleaded, whilst optimax is approx 8.5 cents dearer...
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563311
Ahhhh I stand corrected. But as you said some of the "better" octane boosters have a decent increase, not all :P
As for the idle I honestly dont know. The information I have is written info form the makers of the fuel, maybe Mobile does idle better?
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563327
thats cool, I wasnt really asking a question about it, I was just stating that because mobil seems to be an inferior fuel [in terms of octane at least] I am surprised it seems to feel smoother in my car as compared to ultimate...I still use ultimate because of the octane level :P
https://www.sau.com.au/forums/topic/26631-which-fuel/#findComment-563345
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
