Hi guys, just wanting to know the easiest way to get in contact with 'Mr SHiRTman' who has been a members for many years. Just waiting on some parts (NOT accusing him of ANYTHING) Just think hes having some problems PM's or something so giving him another way of communication, unfortunately I dont have his phone number. If anybody has it help would be much appreciated, via PM.
Wont reply to my PM's, Just need to know if parts on there way or lost in post. Have not received any form of communication since payment (8/4/09).
Thanks for your help,
https://www.sau.com.au/forums/topic/266323-dear-mr-shirtman/
Jin_Man,
Paul has been sent to Queensland for work at the moment, and has been quite busy with this and other things while he is up there. What stuff are you waiting on from him? He's due back home early next week so will probably get back to you then.
Don't worry you will get your parts.
Thanks mate,
Thats all I was after, Just after 02 sensors and have sent a few PM regarding the matter with no reply, yet somebody was logging onto the account daily. Its the last bit of the car and unfortunately it will cost me my deposit for the upcoming track day + 2 weeks of frustration.
Thank you very much for your help, knew it wasn't anything serious, just needed a response.
if it comes down to it you should be able to run the track day without the O2s. just use bolts or the old dead sensors to block the holes, and if you have aftermarket management turn 02 feedback (closed loop) OFF. then it will be sweet, possibly a bit thirsty on cruise unless you tune to suit but other than that no problem.
Hey guys just letting you know Paul is away in QLD on buisness & hasnt logged on since he has basically been in QLD. If ya have seen Shirtman logged on its probably due to his wife stace using home computer. As SAU is most prob his homepage.
Hey guys apoligies for the situation. I have logged in a couple of times but due to Stacey logging in at home failed to realise due to no new message notification that my PM's were full.
Performance Wise did the clever thing and e-mailed me using the e-mail in my sig which recieved a quick response. All sorted...the coil packs will be returned to you when i get back. I was unable to test them for you in the limited time i had them as i didn't have a suitable test car on the dyno in that period.
Jinman, i sourced some O2 sensors for you up here and sent them...you should already have them now.
cheers and my regrets to have caused unnecessary stress...i was called up here at very short notice and have been working up to 22hrs a day on occasions...yes 2 hrs sleep!
Thnx very much. Your response is greatly appreciated.
Oh Paul, Pot Kettle?
Blitz - Nick, I got the email notification of ur post which you must have deleted as obviously it wasnt appropriate.
My response to your biased comments is simple and to stop living in the past.
Edited by performance-wise
Its all good mate, Knew it wasnt anything serious, just needed to know when they would be here. :)
Anybody that can work 22hrs in any single days deserves some slack :)
    • After you start it by holding the throttle wide open, does it then idle correctly without throttle or does it stall? If not it sounds like one of the injectors might be stuck partly open. You could also drain your oil and check for a heap of fuel in it. If it doesn't idle there is something wrong with the tune (unlikely, because it worked when it was tuned), or something changed on your car like the AAC or cold start valve no longer working correctly. BTW, I know we are a multi-cultural forum now, but "gas" makes no sense as a term for the pedal that opens a petrol engine's throttle, either directly or electronically.
    • I bought the NZEFI 1000CC injectors with the ballaster resistor delete pack. It started fine for a few days and even drove it to the Tuners dyno and back. Then one day i drove it to work, and on my way out of the office, the car wouldn't start. Unless i put the gas pedal all the way to the floor and then crank the engine over.  Called the tuner and we tried a bunch of different settings but trying to figure it out now. Anyone else experience this? Haltech Platninum Pro. https://www.nzefi.com/product/nissan-rb-1000ccmin-top-feed-direct-fit-fuel-injector-kit/
    • After the windscreen motor from r31 skyline or pintara, located Grafton NSW
    • I'd do it all again in a heart beat. Well, not all, I'd make some different choices in which mods. But I'd definitely still spend all the money.
    • Hey y'all, Looking local to USA, for just side skirts and rear bumper or half bumper. Pics for reference below: Top is east bear style rear bumper, bottom is uras style rear half bumper. Side skirts are interchangeable.  Thanks y'all!
