ive decided to do a group buy on silverstone semi slicks seeing as there is alot of interest atm.
price is yet to be set but expect to pay less than 200per tyre for a 16" semi-slick in your choice of compound (hard, medium soft) the more people the lower the price
silverstone dont seem to give conventional tyre sizes but the dimensions for the 16" tyre are 625mm dia. and 210mm width
these arent legal for the street either :)
i should have a pair on the back of my car in a couple weeks if people want to check them out. interested people post here or pm
edit: link to the tyres http://www.silverstone.com.my/products/rally/s575.html
https://www.sau.com.au/forums/topic/26635-semi-slick-group-buy/
no worries, there is a 17" version also but ill check price on that today.
ill have mine next week if you want a look rob but they wont be on my car for a few untill wheels are ready then ill test em at the drags.
a few others are buying them for that purpose illl let you know how they go.
rally tyre or not they are designed for tarmac use, i remember gtrken saying he recomends them so they must be worth a go.
i never said they were a drag tyre, so do your whoring somewhere else, this is just to help out people who would like more forwards rather than sideways motion :P
paul, the 17" tyre is designed for up to a 9" rim
yeah we'll see how they go. get me that painters no. steve and ill test them the day there ready at kwinana, have no wheels to put them on atm or id be down there this week
im a little worried as to how an already crunchy/noisy rb20 box is going to hold up to big launches on these tyres tho....
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
