some cars have them stock, and some dont...
millions of people run without one, and i have NEVER heard of a turbo dying because of a no BOV situation...
you'll be fine deano...
  • Replies 53
Ok, here's the thing:
Compressor surge (commonly known as dose) is bad for your turbo. There is no real dispute about this. Whats in dispute is how bad it actually is, ie the simile mentioned before was a tennis ball against a brick wall.
What you got to remember is that if any given turbo has a life of 120K kms then compressor surge isn't gonna do you any favours in regards to life expectancy. From my experiences so far compressor surge is not going to have any affect (other than increased lag b/w gears) in the short term, but if ur looking to keep ur car for a few years and/or have an old turbo on there, I would def be putting on a BOV.
P.S., Ive got a blitz one for sale if u need it :)
how about a bov wound down fairly tight? tight enough to clearly hear compressor surge. when there is enough pressure, it releases back into recirc, but otherwise it doesnt.
thats how mine is, and i dont see any fuel economy issues, or added lag between changes.
a bit off topic, but still in the ballpark :)
Edited by Munkyb0y
This is what Corky Bell has to say about it. But with a name like that, i'm not sure what to believe :blink:
Compressor surge is the rapid fluctuation of turbine speed caused by the throttle's being closed under boost. Rapidly spinning air compressors (turbos) can go unstable briefly when this occurs. The fluctuating speed can be damaging to the turbo and the accompanying noise is obnoxious. The condition can be alleviated with a compressor bypass valve that opens as the throttle closes and allows air exiting the turbo to vent back to the front This keeps the flow up. Many modern turbo cars are equipped with such valving, but seldom are they big enough to handle high-flow, high-boost systems, A useful fringe benefit to these valves is that they reduce lag and perceptibly increase fuel economy.
Obnoxious my ass!!
Edited by PM-R33
My mate put a turbo on a MX5 BOV'less and it lasted about 5 months before the shaft play was quite bad. No shaft play to begin with.
He has another one of the exact same turbo (he baught my old turbos, R34 standards) and is running it with a BOV and it is fine and has lasted already longer then the last one. In that mind that does it for me.
Running a AFM setup Nissan style, likely to hurt economy if anything. Certainly wont help it
Hmm i guess it depends on the car. Running no bov or an atmo bov should have the same effect on fuel economy. I run an atmo bov and still manage about 480km to a tank before the fuel light comes on. (Standard ECU)
My thoughts: Red top RB20DET + FMIC never had a BOV factory, wound it up to 14psi ran it for 3+ years pulled the turbo off and it was exactly the same as you'd expect a 120,000km turbo to be. A little bit of oil but nothing out of the ordinary, it still boosted hard. Car drove great. Put an R33 turbo on and continued running with no BOV, zero problems.
RB25DET S2, blocked the BOV off and the car ran like shit (I still have the factory SMIC). I think the newer ECUs are far more sensitive with their mapping and the airflow changes upset it.
I would have no qualms whatsoever running without a BOV, providing the ECU could handle it.
there is always shaft play.
Did a turbo swap on a mate's RB25, the brand new HKS we put on had about 3x the shaft play of his stock item. Excessive shaft play is a problem, minimal is not.
blades are spinning at several thousend rpm, them coming to a complete stop when air is pushed back through? it has 2 do sumthing
No. Do you think compressor wheels are made of paper mache? They have to be strong enough to compress air while being hot and spinning at a hundred thousand RPM. Do you think a little bit of chuffing noise is going to upset them? Doubt it.
Most turbos last longer than that, but say 120k with a BOV and 115k or 110k without. Who cares?
Too many variables, or just bad luck. He was probably more careful with the second turbo as well.
logically speaking it wont have the same effect...
but every car/driver is different... i said it wouldnt help. :)
Here's a simple test.
First, obtain a tennis ball in the opposite hand that you throw with.
Subsequently, go outside your house, find a nice spacious brick wall, and through it at the wall.
Then, inspect the wall to see if there is any damage...
Same principle applies to air hitting the turbo fins.... :):ph34r:
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
