people don't expect too much from a stock R32 GT-R these days, especially when other person is driving when driving a modified Evo or something.
im not saying a stock looking one can't be made faster then a stock one, But a stock one isn't a slow car either and I don't know anyone who would look at a Gtr and say "look at this piece of shit, it's got no hope" their reputation is just to great
  • Replies 200
+1
+1 on this. No skyline (regardless of model) will ever be a sleeper. No matter how stock it looks.
I have to dissagree, My 32 4 door was stock and no one even knew what it was. I had to keep telling people it was a r32 skyline. i have never been pulled up, followed or other wised had any issues with the cops.
I have to dissagree, My 32 4 door was stock and no one even knew what it was. I had to keep telling people it was a r32.
I thought The round tail lights would of been a dead give away?
N13 Nissan pulsar with a CA18DET, I used to have one had 350hp atw & ran 12.2@124mph wheel spin 1st second third. Would bag the tyres at 100kph on the highway. I miss it
Here is a vid of it at willow bank when it was putting down about 220hp
Edited by GTR260
Mates Ke55 with ca18det, no photos with granny rims but has venetians old man hat and lawn bowls stickers :P
32GTR seats may be the give away lol
Thats awesome! Hey, were the first few pics taken at port Adelaide? Old woolsheds?
Edited by AshR34GTT
nope as they are diffrent on the sedan to the coupe.
Ah ok, fair call then.
Yeh we took a fair few that day
Lol, that area is awesome for all sorts of photo shoots. It's used a lot. Must admit the first time I seen it I thought 'photo shoot'.
i still think the best streest sleeper is the MX83 Cressida
They're getting a bit 'done to death' - but you can't be the combination of a built 1.5JZ single turbo with a stout A340 transmission behind it, R33 front brakes, coilovers, MA70 supra LSD, sticky tyres on stock rims - all underneath a brown/beige metallic paint, white venetians, doyleys on the cream leather recliner seats and a 'I <3 BOWLS' sticker on the rear window.
They're the penultimate grandpa car, and nobody would even think twice. I'd even run a massive network of mufflers just to make sure it was virtually silent around town........and an external gate to screamer.
EDIT: just re-read this thread from back to front - seems like everyone else has the same idea. So. I concur.
Edited by SMOKEYC34
Didn't read entire thread, but my pick would be a au/ba/f falcon s/wagon. F6 motor, 6sp auto, and good lsd for the solid axle. Sticky tyres & tune for 400kw+ = :w00t:
Edited by _x_FiReStOrM_x_
My mate's 808 is a great example of a nice street sleeper, sure the whole old Mazda rotary has been done a lot but...
Smoothie wheels, red/white wall tyres, rear venetians and a sun visor.
Oh, and it also runs 10's with a full interior and numberplates - not bad!
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
