Hey guys,
I havebought a 1989 C33 laurel that is auto and running a firey CA18 engine (made the silly mistake of buying it when i didn't know much about the engines in these, but hey it had low k's :P ) and im looking to do a full RB20det manuel conversion as i am not looking for a fully fledged drift mobile, i am just wanting something thats a tidy street crusier that can pick up and go when the need be.
I have a guy who is going to do the conversion for me and i am waiting on a parts list from him but i though i would ask here first. But is anyone able give me a parts list as im guessing it wont be as straight forward as a RB20de to RB20det conversion? I have asked a few people but everyones part list is different so i've come here to see if i can get a real straightforward list of every nook and cranny i will need and all the possible problems that i will be looking at running into.
So any help will be much appreciated from anyone that has done the conversion in the past and can point me in the right direction.
Cheers
Not a huge fan of the wheels but its the least of my worries at the moment.
The beast of an engine.
https://www.sau.com.au/forums/topic/266447-c33-manual-conversion-help/
What part of NZ are you in?
would be worth jumping on nissan silvia nz forum to ask/source your gear
I will give you a bit of a list as i have done mine in last 6 months.
I presume it has the foot brake instead of hand brake?
handbrake and cables
Gear stick boot and centre consol
clutch pedal box, pedal, clutch master and slave + lines - i used r33 gear here but i had to moddify the pedal box to fit.
front half of tail shaft
I cut the brake pedal down as its huge for autos.
not sure what you plan on doing for wiring but you will need to bridge the inhiditor plug for auto, its located in a bunch of plugs by battery.
I havn't stated what motor box bits you need as this should all come as manual package.
theres probally more but theres a start.
Hey guys,
I havebought a 1989 C33 laurel that is auto and running a firey CA18 engine (made the silly mistake of buying it when i didn't know much about the engines in these, but hey it had low k's :D ) and im looking to do a full RB20det manuel conversion as i am not looking for a fully fledged drift mobile, i am just wanting something thats a tidy street crusier that can pick up and go when the need be.
Cheers
Cheers for the help mate, I'm located in Auckland. I was going to give the Silvia guys ago but didn't really know whether or not they would just lead me to a differant forum and i thought this was sort of the closest forum to what i was looking for.
  • 3 weeks later...
Handbrake - R32 and cables to suit - make sure its mounted on an angle or it will get in the way of reverse gear. I know from experience haha.
Manual centre console - Cefiro
Clutch pedal box - S13 or A31
Clutch lines and cylnders slave/master - A31 R32
Tailshft - either A31, custom one piece or you will have to join to shafts together i think its an r32 front shaft and the auto rear shaft. (cant remember exactly).
As MattNZ said you'll have to brigde the park neutral start swith located next to the fuse box (from memory its the thickish wires 10 gauge i think or maybe 12 black and brown wires.)
Engine side of things its best to get a front cut as everything else you will need will be in it.
Loom may be tricky as its been rewired to run the CA18.
hope helps ya out a bit.
good luck with it mate.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
