i just gave my 33 a little fang up the street with a on spot u-turn and wen i got to the end of the street i notice that there was more noise coming from the engine bay... it seems like the fan is working harder or spinning more if that makes any sense... it is normal when the car is idling but if the rpm rises so does the fan noise or the fan rpm.... just sounds like this massive V8 roaring down the street with a huge as fan... not a rathered refined 6cyclinder turbo...
i didn't know wat to search for so yeah sorry guys...
https://www.sau.com.au/forums/topic/26645-fan-problem-help/
AFAIK, the fan on R33 has a viscous type centre, so the fan should only work when the centre warms up. these centres can die.
As an option (if you have the dollars, I dont know how much a stock fan will cost) buy a twin thermo fan set up from a dismantler, and have that fitted instead. It will need to be adapted, but will give you more power (less load on the crank) and better cooling.
they can be bought from as little as $85 dollars, perhaps less. Go into a radiator shop, they should be able to hook it up with a thermostat to only run when the car gets hot.
https://www.sau.com.au/forums/topic/26645-fan-problem-help/#findComment-562913
the fan always spins.
the skylines have what they call CLUTCH fans.
it should spin faster with the revs when it gets hot.
It is normal for them to seize up.
You can get a scond hand one from the wreckers for $50 or a brand new one for $150 (these prices are for the clutch part only)
when asking for it, you need to ask for a VL commodore one.
they are identical.
Thermo fans are the other option but it requires some fiddling to get them fitted properly over your radiator and connect up a thermostat and so on.
There are only 4 bolts to take off to remove the the whole fan assembly off your water pump.
then another 4 bolts (I think) to take the fan off the clutch.
https://www.sau.com.au/forums/topic/26645-fan-problem-help/#findComment-563024
they run but they are sort of passive.
the fan always spins, but when it gets hot, the fluid in the clutch bit makes the plates grap and it turns as fast as the crank does.
normally, when it's hot, you accelerate and you can hear it howl with the revs until about 4000rpm, you hear the fan sound die down.. but it still spins.. just not at the same speed as the crank.
https://www.sau.com.au/forums/topic/26645-fan-problem-help/#findComment-563166
yeah mine can be turned BUT WITH SEVERE FORCE and only abt 3 cms each way.... so i guess that means that the clutch fan has chucked in ay... damn... there goes another $100 wasted... would've been good to use that to buy a case of beer for u guys... thanks heaps for the help!
https://www.sau.com.au/forums/topic/26645-fan-problem-help/#findComment-564237
    • This could be sold and shipped to the US for many gold pieces. RMS has no say in that. Ask various Western Sydney inhabitants how it works.
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
    • Their 240Z with the RB26 would be a real nice thing to have in a garage to come out for an occasional weekend cruise It's such a cool thing in so many ways Sadly, we have a blue 240Z shell that I walk past every day, just sitting outside a shed at work, it has been slowly disintegrating and falling apart into the ground for the last few years, the owner cannot be found, and I am unable to "claim it" I've been told by work and the RMS, the rust in the body is excessive though, and it has had most of the salvageable stuff, like panels, trim and switch gear stripped off it over the last year or two, work keeps threatening to put it in one of our metal scrap bins, I wish they did though, as it makes Mark sad walking past it
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
