In the states they came out with the VQ45 as per what is in my F50 Cima, they are fitted with a RB25DET Neo and 4WD but they wont be seen for a while due to emissions testing.
Jash and I got them on the RAWS schedule because we see them as a very good value for money car and with a few mods will go quite well.
https://www.sau.com.au/forums/topic/266452-y34-gloria/#findComment-4552084
only prob is that the sat nav and all the controls are in japanese, and the tv dont work here either
does anyone know how or if you can change them to work over here.
worked some of the menu's out so far.
and some more pics
:D
https://www.sau.com.au/forums/topic/266452-y34-gloria/#findComment-4555535
ooo.. didn't realise there was one of these in WA... the guy who imported my legnum for me (kristian at iron chef imports) showed me them when they got approval, and i was very interested in buy one..
lowered on a good set of rims and these things look fantastic. :laugh:
https://www.sau.com.au/forums/topic/266452-y34-gloria/#findComment-4559443
nice to see one on the road, mine will be on the road in 2 weeks, its on its way from brisbane now.
as far as mods go, there isnt much apart from looking on yahoo japan. A few companies have cat back exhausts and pod filters, thats about as far as it goes ha ha. i wonder if any parts from the VQ35 fit...
i went through Kristian for mine.
i have a set of 19 inch rims on mine that i will be selling when it gets here if you're interested, i just put brand new tyres on them.
i have lowering springs on their way too just to drop it a bit for now
https://www.sau.com.au/forums/topic/266452-y34-gloria/#findComment-4564043
have you changed the gear box fluid yet? just read the horror story of what happened to Ben's cedric with the CVT, hope yours doesn't crap itself like his did.
your interior is so nice though, almost makes me want to buy a donor car with the series 2 interior and put it into my car
https://www.sau.com.au/forums/topic/266452-y34-gloria/#findComment-4567628
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
