hrm HID is nice and pretty but if it's not going to last longer than halogen then i guess i'd just pass it... say if the ballast blows because of the hi/lo beam switch reason then the replacement cost is pretty high...
plus i'd have to adjust my headlights lower so it won't glare oncoming traffic... but that reduces visibility
Edited by chiksluvit
theres a fix for the hi/low beam switch problem your talking about for 33's atleast (and i dare say for 32's aswell).
I've rewired my headlights so that the low beams dont actually turn off when i go to highbeam, so on high beam all 4 lamps are lit.
So while the high beams might suffer from a slightly higher failure rate due to flicking on off, the low beams should avoid the issue.
the howto for this mod is somewhere in the diy section, cant recall the link but do a search for "dual headlight" and it should come up.
As far as colour goes, i purchased mine of nyt and after speaking to him i went with 6000k and 8000k, which is "damn white" and "damn white with a touch of blue", both from the "goddamn bright" collection. From what i've been told the light penetration actually drops after about 8000k, so it goes bluer but dimmer if you will (if you like the colours nyt also sells 12000k, which is purple). Given the problems you might face with legalities of HID's i'd go 8000k max as any higher will not only stand out due to brightness, but also due to it being a funky colour.
this HID kit your enquiring about is actually pretty good..
its made in china & generic... but its pretty reliable for what it is..
thats the one i fit on the Yaris
hey guys thx for the tip,
I wanna get two different colours to make it look like white and purple.
so i should get the kits that's 6000k and a 10,000k?
Plus the link i just put up only stock 6000k.
Anyone know a good china made band for more bluer colour?
Thank you
SLinky-A :):thumbsup::)
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
