the induction pipe is a piece of shiit. installed it today. doesnt look like it hooks up with the BOV return but it doesnt hook up to the oil pipe to the head. had to get some new hose. shiit quality too. got it and it looked like it had been slid on a floor. no extra induction noise and no dose or anything like that. i suggest u get a custom one made up. just a couple of silicone adaptors, say 90degree bent 2inch to 3inch piece (guessing), to a 3 inch piece of pipe and another silicone joiner to the AFM. then just drill holes and weld on the extras u need.
What did you expect would happen? The stock intake pipe has holes for the metal bov return and oil breather to slot into so obviously that wasnt going to work without some hoses. And when you look at the placement, its not even near where the originals holes are.
I dont understand how these guys sell so many when everyone who buys one just ends up pissed off. Classic example of getting what you pay for.
And what do you mean 'no dose'. If your bov is blocked off then it should dose even with the rubber intake and be a fair bit louder with the metal intake. Unless your still running an air box, in which case dont ever expect a loud flutter if thats what your after..
DASHMAT!!! NONONONONO!!
Spray-on dash protector...that will do fine! Just give it a fresh coat once a month. Basic interior maintainance. Not hard.
Thanks...... Wasn't aware of this product.
To SLY_25T. Sorry to hear that the induction pipe was such a piece.....I guess I won't be getting that one then :cool:
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
