give it a hit in the wet around a corner and youll see the torque gauge move :P
ive actually worked out how to get the stagea sideways in the wet!!
It must be rocket science if it took you to work it out lol.
I'd prefer not to be sidewise unless I'm in a skidpan :dry:
  • Replies 52
ARX got he 6cd radio from what I have seen. that said the wiring IS THERE! if you are up for it find the cluster and plug it in.
Here's one I found, new, on rhdjapan.com: http://www.rhdjapan.com/jdm-low/NISMO-M35-...ers-White-56190
ahh damn!!! ok ill find more shit you guys dont have in your povo packs :P
LOL, cue the games of "Hey, have you got one of these???"
lol it's easy to get it sideways in the wet..
i got it sideways about 5 times on my way home..(unintended)
easy to control..
im used to all wheel slides coming from a bunch of awd performance cars..
then again..
I might have to try harder lol
I think mine sits a bit steadier due to Nismo S-Tune suspension, the weight doesn't move around quiet as much as standard suspension M35's.
hahaha yes i cant wait for that tonight! whos coming???
and stephen, yeah firmer suspension will make it MUCH easier to get sideways. hence why it took me longer, a wet night and 5 people in the car :P
2003 RS FOUR here, with the guages in the centre (except my boost guage is broken - barely works - 99% of the time it sits on full vacuum even under heavy throttle when i can hear the turbo spooling).
no "stagea" on door sills, no leather, no heated seats, no rear air-con vents... you guys suck lol :(
but hey...i do have guages...even if only 2 of them are working (but the volts one isn't very interesting and i dont drive fast enough for the front torque one to move much either).
no overdrive button - but then s2 stageas dont have one either. no real need when you have tiptronic.
Broken boost gauge eh? Yep, me too.
Hasn't worked properly since 2 weeks after I got it.
Had a number of looks at it and so have RE Customs.. Nothing doing.
Have given up on it and will be looking at getting a Nismo cluster (in the distant future).
Jack one rear wheel off the ground, with handbrake off, rotate wheel. If wheel turns, no lsd. Friction from lsd will prevent you from rotating wheel. Good luck, hopefully more free lsd's will be found!
Erm, just so you know, with one wheel up and handbrake off, my old man's Prado's wheel can be rotated & it has an LSD.
Maybe I will just wait 'till the weekend and see if there is anything stamped on it instead!
Yeh, you're right, spotted this with my mates supra a while ago, and it locks up hard on the street, but it still had resistance. wouldn't free wheel. It's more just a simple rule of thumb. Definitely will be something oil related on the diff tho'
In relation to the LSD and how do you know if you have it question, I have found that in the RS4-S, i can hear the LSD when turning 90 degrees up and out of our underground carpark. I am only doing 5 kph or less and can simply hear the inner tyre going "chirp chirp chirp chirp".
Hope this helps !
Edited by Jezboosted
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
