give it a hit in the wet around a corner and youll see the torque gauge move :P
ive actually worked out how to get the stagea sideways in the wet!!
It must be rocket science if it took you to work it out lol.
I'd prefer not to be sidewise unless I'm in a skidpan :dry:
  • Replies 52
ARX got he 6cd radio from what I have seen. that said the wiring IS THERE! if you are up for it find the cluster and plug it in.
Here's one I found, new, on rhdjapan.com: http://www.rhdjapan.com/jdm-low/NISMO-M35-...ers-White-56190
ahh damn!!! ok ill find more shit you guys dont have in your povo packs :P
LOL, cue the games of "Hey, have you got one of these???"
lol it's easy to get it sideways in the wet..
i got it sideways about 5 times on my way home..(unintended)
easy to control..
im used to all wheel slides coming from a bunch of awd performance cars..
then again..
I might have to try harder lol
I think mine sits a bit steadier due to Nismo S-Tune suspension, the weight doesn't move around quiet as much as standard suspension M35's.
hahaha yes i cant wait for that tonight! whos coming???
and stephen, yeah firmer suspension will make it MUCH easier to get sideways. hence why it took me longer, a wet night and 5 people in the car :P
2003 RS FOUR here, with the guages in the centre (except my boost guage is broken - barely works - 99% of the time it sits on full vacuum even under heavy throttle when i can hear the turbo spooling).
no "stagea" on door sills, no leather, no heated seats, no rear air-con vents... you guys suck lol :(
but hey...i do have guages...even if only 2 of them are working (but the volts one isn't very interesting and i dont drive fast enough for the front torque one to move much either).
no overdrive button - but then s2 stageas dont have one either. no real need when you have tiptronic.
Broken boost gauge eh? Yep, me too.
Hasn't worked properly since 2 weeks after I got it.
Had a number of looks at it and so have RE Customs.. Nothing doing.
Have given up on it and will be looking at getting a Nismo cluster (in the distant future).
Jack one rear wheel off the ground, with handbrake off, rotate wheel. If wheel turns, no lsd. Friction from lsd will prevent you from rotating wheel. Good luck, hopefully more free lsd's will be found!
Erm, just so you know, with one wheel up and handbrake off, my old man's Prado's wheel can be rotated & it has an LSD.
Maybe I will just wait 'till the weekend and see if there is anything stamped on it instead!
Yeh, you're right, spotted this with my mates supra a while ago, and it locks up hard on the street, but it still had resistance. wouldn't free wheel. It's more just a simple rule of thumb. Definitely will be something oil related on the diff tho'
In relation to the LSD and how do you know if you have it question, I have found that in the RS4-S, i can hear the LSD when turning 90 degrees up and out of our underground carpark. I am only doing 5 kph or less and can simply hear the inner tyre going "chirp chirp chirp chirp".
Hope this helps !
Edited by Jezboosted
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
